Specific heat : solids and liquids
The discussion focuses on calculating the heat required to raise the temperature of lead and the heat necessary for its phase change from solid to liquid. The specific heat of lead is established as 31.0 calories per kilogram per Celsius degree. To find the heat needed to raise the temperature of 1.30 kg of lead from 23.0 degrees Celsius to its melting point of 327.3 degrees Celsius, the formula used is Q = m * C * ΔT. Additionally, the heat of fusion for lead is provided as 24.5 x 103 joules per kilogram, which is essential for calculating the heat required for the phase change.
  • Understanding of specific heat capacity
  • Knowledge of heat of fusion (latent heat of fusion)
  • Familiarity with the formula Q = m * C * ΔT
  • Basic principles of thermodynamics
  • Research the calculation of heat transfer in phase changes
  • Learn about specific heat capacities of various materials
  • Explore the concept of latent heat in different states of matter
  • Study the applications of thermodynamics in real-world scenarios
Students studying thermodynamics, physics educators, and anyone seeking to understand heat transfer in solids and liquids.
airforce840
I am having a lot of trouble with these types of problems.. this one is on a homework assignment and i don't know where to begin.
heres the problem :
The sepcific heat of lead is 31.0 calories per kilogram per Celsius degree. (a) Find the heat necessary to raise the temperature of 1.30 kg of lead from 23.0 degrees Celsius to its melting point, 327.3 C. (b) Find the heat necessary for the phase change from solid to liquid. The heat of fusion for lead is 24.5 x 10^3 joules per kilogram.
Any help is great.
Thanks in advanced
Patrick
What equation do you have that relates heat, specific heat, and temperature change?
What equation do you have that relates heat, heat of fusion (aka latent heat of fusion) and mass?
i feel so stupid.. these problems are quite easy once i looked at it again.. all i got to do is use m C delta T and I am good 2 go.
10K
  • · Replies 21 ·
