Coefficient of friction-someone help me, please
  • Thread starter Thread starter Inka
    Coefficient
This discussion focuses on determining the coefficient of kinetic friction for various surfaces using an aluminum block. The experiment involves sliding the block down different surfaces while recording distance, time, and velocity. It is established that the coefficient of kinetic friction remains constant regardless of the mass of the block, although a heavier block increases the normal force, leading to a higher frictional force. The participants acknowledge the limitations of their equipment and the discrepancies between theoretical models and real-life observations.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of friction and its coefficients
  • Basic knowledge of experimental physics and data collection methods
  • Ability to perform calculations involving forces and motion
  • Research the principles of kinetic friction and its applications in physics experiments
  • Learn about the limitations of friction models in real-world scenarios
  • Explore methods for improving experimental accuracy in measuring friction
  • Investigate the effects of surface materials on friction coefficients
Physics students, experimental researchers, and educators interested in understanding friction and its practical implications in physical experiments.
Inka
Im not sure this is in the right place, I suppose it could be under maths or physics, but this seems more appropriate as it's a physics experiment. Anyway, I'm trying to determine the coefficient of kinetic friction for various surfaces by sliding an aluminium block down these varying surfaces and recording the distance, time and velocity and so on. I am also doing this same procedure but increasing the mass of the block, and I was wondering whether this should have any effect upon the coefficient of the surface or if the coefficient should stay constant regardless of increased mass. Any help would be GREATLY appreciated, I'm going nuts here because half the data I've gathered seems to make no sense (logical considering the crappy equipment I had to work with) and I don't know what I'm supposed to be seeing!
Thanks:smile:
The coefficient should remain the same irrespective of the mass of the block. However, a heavier block will yield a larger normal reaction by the surface. This normal reaction will lead to an increased friction force, since
[tex]F_{fric} = \mu_{slide}N[/tex]
where [tex]\mu_{slide}[/tex] is the coefficient of kinetic friction and N is the normal reaction (N = -mg for a horizontal surface).
Don't be too perturbed. As far as they go, the coefficient of friction model is pretty piss poor at accurately describing a real life friction scenario. Stick with it, just don't expect real life to repeat the theory too closely.
  • · Replies 18 ·
  • · Replies 71 ·
12K
  • · Replies 16 ·
