Magnet Valves: What Are They and How Do They Work?
The discussion centers around the concept of "magnet valves" within the context of a cooling system design. Participants explore the definition, functionality, and applications of these valves, particularly in relation to solenoid valves and their use in safety mechanisms.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant seeks clarification on what a magnet valve is and its relation to traditional magnets.
  • Another participant proposes that a magnet valve functions similarly to a solenoid valve, incorporating a permanent magnet to allow operation during power outages, particularly in safety applications like gas cookers.
  • A third participant questions the mechanism of operation, asking whether the magnet is physically moved or if it is held in place by an electromagnet, suggesting that a spring might be a more logical component if the latter is true.
  • A fourth participant expresses unfamiliarity with the term "magnet valve" but suggests it likely refers to a solenoid valve, emphasizing the role of an iron core in a magnetic field for operation.
Participants do not reach a consensus on the exact definition or mechanism of magnet valves, with multiple interpretations and questions remaining unresolved.
Some assumptions about the operation of magnet valves are not fully articulated, and the discussion lacks clarity on specific definitions and mechanisms involved.
TSN79
I'm doing some drawings on a cooling system, which includes a couple of so called "magnet valves". What excactly is a magnet valve, and does it actually have anything to do with the normal type of magnets?
I believe it to be as per a normal solenoid valve, but with a permanent magnet so that when power cannot be supplied (in an emergency, for instance) the valve can still actuate to an off position. They're used in gas cookers as safety devices, I believe.
So do you physically move the magnet into position, or is the valve held against it by a stronger electromagnet, or what? If the latter, a spring would make more sense. If the former, why not just a lever? :confused:
I have never personally heard of the term. However, it makes sense that it is simply a solenoid valve since the entire operation is based on moving an iron core in a magnetic field.
11K
