Snell's law of refraction problem
This discussion focuses on applying Snell's law of refraction to determine the angles of refraction for red light (660nm) and violet light (410nm) as they pass through a flint-glass prism. The indices of refraction are specified as 1.662 for red light and 1.698 for violet light. The calculated angles of refraction upon emerging from the prism are 32.8 degrees for red light and 33.6 degrees for violet light. The discussion provides a step-by-step breakdown of the calculations using Snell's law, confirming the final results.
  • Understanding of Snell's law of refraction
  • Knowledge of indices of refraction
  • Basic trigonometry, including sine functions
  • Familiarity with light wavelengths in a vacuum
  • Review detailed applications of Snell's law in optics
  • Explore the concept of total internal reflection
  • Study the properties of different materials' indices of refraction
  • Investigate the effects of wavelength on refraction angles
Students preparing for physics exams, educators teaching optics, and anyone interested in the practical applications of light refraction in materials science.
rockind78
Hello everyone,
I am reviewing for a test tomorrow, and I seem to have come across what would seem like an easy problem, but its answer has eluded me for the time being. I am hoping you guys can help.
Horizontal rays of red light (660nm in a vacuum) and violet light (410nm in a vacuum) are incident on the flint-glass prism showin in the drawing. The indices of refraction fro the red and violet light are 1.662 and 1.698 respectively. What is the angle of refraction for each ray as it emerges from the prism?
The answers are 32.8* for the red and 33.6 for the violet. I just don't know how to arrive (correctly) at these answers.
*Image shows a right triangle, with angles 19* and 71*. The right angle and the 71* angle compose the base.
Any help would be greatly appreciated. Thank you.
Review Snell's law of refraction:
n1sinθ1 = n2sinθ2
Hey there,
Snell's law of refraction can definitely be tricky, but let's break it down step by step to solve this problem. First, let's define some variables:
n1 = index of refraction for the incident medium (in this case, vacuum)
n2 = index of refraction for the refracted medium (in this case, flint-glass)
θ1 = angle of incidence (the angle between the incident ray and the normal)
θ2 = angle of refraction (the angle between the refracted ray and the normal)
Now, let's use Snell's law: n1sinθ1 = n2sinθ2
For the red light: n1 = 1 (since it is in a vacuum) and n2 = 1.662, so we have: sinθ1 = 1.662sinθ2
Similarly, for the violet light: n1 = 1 and n2 = 1.698, so we have: sinθ1 = 1.698sinθ2
Now, we know that the angle of incidence for both the red and violet rays is 71 degrees (since it is the complementary angle to the 19 degree angle given in the drawing). So, we can plug in this value for θ1 in both equations and solve for θ2.
For the red light: sin(71) = 1.662sinθ2
θ2 = sin^-1(0.674) = 42.4 degrees
For the violet light: sin(71) = 1.698sinθ2
θ2 = sin^-1(0.666) = 40.3 degrees
However, these angles are the angles of refraction inside the prism. To find the angle of refraction as it emerges from the prism, we need to use Snell's law again, but this time with n1 = 1.662 and n2 = 1 (since the light is now going from the flint-glass back into vacuum). This gives us:
sinθ2 = 1sinθ1 = sin(42.4) = 0.682
θ2 = sin^-1(0.682) = 41.3 degrees
Similarly, for the violet light, we have:
sinθ2 = 1sinθ1 = sin(40.3) = 0.656
θ2 =
32K
10K
