Two carts and their initial acceleration
The discussion revolves around the initial acceleration of two carts connected to different forces: one cart is attached to a hanging weight, while the other is pulled by a person. Participants explore the implications of these forces on acceleration, considering factors such as tension in the rope and the mass of the systems involved.
  • Some participants propose that the cart with the person pulling will have the highest initial acceleration due to the immediate application of force compared to gravitational force.
  • Others argue that the initial acceleration depends on the force exerted by the person; if the person can pull with a force greater than the weight of the hanging mass, then that cart will accelerate more.
  • Another viewpoint suggests that there would be no difference in acceleration unless the person changes the amount of force they pull with.
  • It is noted that the tension in the rope connected to the hanging mass is always less than the weight of the mass, which affects the acceleration of that cart.
  • Some participants question why the tension is less with the hanging mass, suggesting that if the system is frictionless, the tension should remain constant and equal to the weight.
  • A later reply clarifies that while the tension remains constant, it does not equal the weight of the mass, as that would prevent the mass from accelerating.
  • One participant introduces the concept of moment of inertia, arguing that the combined system of cart and weight has a larger moment of inertia, leading to less initial acceleration compared to the cart with the person.
Participants express differing views on the initial acceleration of the carts, with no consensus reached. Some believe the cart with the person pulling accelerates more, while others argue there is no difference unless the pulling force changes.
Participants discuss the implications of force application and system mass on acceleration, but the discussion does not resolve the mathematical relationships or assumptions regarding the forces involved.
suyver
As promised in another thread: Riddle me this, riddle me that...
There are two carts on the table. For each cart, there is a rope attached on one side to the cart and via a pulley it is hanging over the edge of the table. On the other end of one rope a 5 kg weight is attached and on the other rope a person pulls with a force corresponding to 5 kg. Which cart has the highest initial acceleration?
a. The cart with the weight.
b. The cart with the person.
c. There is no difference.
I think that the cart with the person pulling the rope will have the highest initial acceleration. This is due to the difference between force and thrust: the person pulling the rope immedialtly applies a thrust to the system, while gravitation does not.
Any thoughts, anyone?
It depends on how hard the person is capable of pulling. If he can pull at more than 50N (the weight of the weight) then the initial accel of that cart he pulls on will be higher.
There would be no difference in acceleration.
For there to be a difference, the person would have to change the amount of force he pulled with
This one's easy, suyver!
First, I assume you mean that the person pulls with a force equal to the weight of the 5 kg mass.
In any case, whichever exerts the greatest tension on the rope will create the greatest acceleration. For the cart plus weight case, the tension in the rope is always less than the weight of the hanging mass. In the cart plus person case, by stipulation, the tension in the rope equals the weight of the hanging mass.
So, the answer is b: the cart with the person accelerates most.
Agreed!:smile:
I'm not sure I get your point. In both arrangements the force is applied immediately; the hanging weight just applies less force.
I don't get it. Why is the tension in the rope always less with the hanging mass? If the carts are frictionless, then wouldn't the tension in the rope connected to the hanging mass remain constant. The force from the weight is constant isn't it?
The tension remains constant, but it does not equal the weight of the mass. If it did, the mass wouldn't accelerate, would it? :smile:
How so? With an aceleration force, if the force is constant, the acceleration is constant.
In any case, all he asked was about the INITIAL acceleration.
Yes it is, but that mass has to accelerate the cart and ITSELF. When you pull on the rope(using Doc's stipulation on the force being the actual tension in the rope), you are only accelerating the cart.
Ok, i think i get it now... In order for the person pulling to keep his pulling force at 50 N, he has to keep the rope tension at 50 N.:smile:
and the rope tension on the cart from the hanging mass is always less? This makes sense to me intuitively, but I still don't fully understand it.[b(] Is this because of F = (m + m2)a?
And still the first 3 answers were all different! That's the nice thing about physics: even classical mechanics can put one over on you...
Yes, that's what I ment. It's always hard to formulate such a configuration in another language. I agree with your answer, by the way.
I have, maybe, even another line of reasoning that also leads to answer B: In the case of cart+weight, both the cart and the weight will need to get an initial acceleration. The combined system will have a larger moment of inertia than the cart-only system. Therefore, the initial acceleration must be les in the combined system than in the cart-only system. I personally feel that this is a more insightfull argument. What do you think?
How right you are!:smile:
I think you have the right idea. In both cases, the external force (mg) is the same. In the cart+person case, that force accelerates the cart; but in the cart+weight case, that same force must accelerate both the cart and the weight. Same force--more mass--less acceleration: makes sense to me!
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 38 ·
