How can I find the x-intercept of a cubic polynomial?
  • Thread starter Chocolaty
  • Tags
    Graphing
In summary, when sketching the graph of a cubic polynomial, such as f(x) = x^3 + 3x^2 - 9x + 5, to find the x-intercepts (where y = 0), you need to look at the integer factors of the constant term (x^0). In this case, the factors of 5 are +/-1 and +/-5. You can then plug in these values into the function and determine which one results in a y-value of 0. This value will correspond to an x-intercept. Additionally, if one of the factors is found to be 0, it can be used to long divide the polynomial and find more intercepts from the factored form.
Chocolaty
48
I have to sketch the graph of this function:
f(x) = x^3 + 3x^2 - 9x +5
But how can I find the x-intercept (where y = 0) in this function?
for cubic polynomials in order to find the x intercepts you need to look at hte integer factors of the constant (x^0) term
here look at the factors of 5 they are
+/-1,+/-5
so find f(1), f(-1), f(5), f(-5) and determine which one is zero
SUPPOSE (not necessarily true) f(1) = 0, then x = 1, and x-1 is a factor
thereafter long divide the polynomial by x-1 and then you can find more intercepts easily from teh factored form.
What is an x-intercept graph?
An x-intercept graph is a visual representation of an equation or function that shows where the graph intersects the x-axis, or where the y-value is equal to 0. It is used to determine the roots or solutions of an equation.
How do you find the x-intercept on a graph?
To find the x-intercept on a graph, look for the point or points where the graph crosses the x-axis. These points will have a y-value of 0. You can also find the x-intercept by setting the y-value to 0 in the equation and solving for x.
What does the x-intercept represent?
The x-intercept represents the value of x when the y-value is equal to 0. In other words, it is the point where the graph crosses the x-axis and has a y-value of 0. This is also known as the root or solution of the equation.
How do you graph an equation using x-intercepts?
To graph an equation using x-intercepts, first find the x-intercept points by setting the y-value to 0 and solving for x. Then, plot these points on the graph and draw a line connecting them. You can also find other points on the graph by plugging in different values for x and solving for y.
What is the difference between x-intercepts and y-intercepts?
X-intercepts are the points where the graph crosses the x-axis and have a y-value of 0. Y-intercepts are the points where the graph crosses the y-axis and have an x-value of 0. In other words, the x-intercept is the root or solution for the equation when y=0, while the y-intercept is the root or solution when x=0.
  • General Math
