Does 6 kW Cooling Fan = 6 kW of Heat?
The discussion revolves around the relationship between the power consumption of a cooling fan and the heat it contributes to a room. Participants are exploring the implications of a 6 kW cooling fan and its effect on room temperature.
  • Participants are questioning whether the 6 kW power usage of the fan translates directly to 6 kW of heat added to the room. There are discussions about the efficiency of the fan's motor and how much energy is converted into heat versus used for air movement.
The conversation is ongoing, with some participants seeking clarification on the original question and others providing insights into the mechanics of the fan and its cooling capabilities. There is no explicit consensus yet, but various interpretations of the fan's function are being explored.
Participants are considering the efficiency of the fan's motor and the assumptions about energy conversion, which may affect the overall understanding of the cooling requirements for the room.
TSN79
If one has a cooling fan that uses 6 kW, does that automatically mean that the room receives 6 kW worth of heat?
Could you elaborate upon the question? The answer is going to be 'no', but I'm not really sure what you're talking about.
Well, I'm doing a calculation on a rooms need for cooling. This need is of course linked to how much heat gets into the room during some period of time. Now, there is this fan in the room that has an effect of 6 kW, but am I to assume that all this energy is converted into heat and added to the room so that there would just be another 6 kW for the cooling system to remove? Or will only a portion of this energy actually be turned into heat?
It's still a little vague. From your first post, I thought you meant that the fan drew 6KW in order to operate. This time, it seems that you mean its cooling capacity (which doesn't really apply) is 6KW. The fan itself will only move air, not cool it. In that case, the heat that it supplies to the room is waste from the motor. I think that this is a Fred or Clausius sort of question, or Astro. Come to think of it, isn't this Russ' specialty? Anyone but me... help!
I would say that it depends on the efficiency of the motor. Whatever energy is not used for pushing air of those 6 KW then is heat.
either way i don't think a motor by itself woulf cool the room, if you aimed it at water on the room then that would help (until the water recondensated)
  • · Replies 19 ·
  • · Replies 30 ·
