Integrating 110*1.10^(t) from 0 to 35: Solution
The discussion revolves around the integration of the function 110*1.10^(t) over the interval from 0 to 35. Participants are exploring the process of finding the integral and discussing related exponential functions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster inquires about the method to calculate the integral from 0 to 35 and references a textbook explanation regarding the use of constants and integrals at the bounds. Some participants suggest using properties of exponential functions to facilitate the integration process.
Participants are actively engaging with the problem, with some offering hints and alternative representations of the function. There is an ongoing exploration of different integration techniques, but no consensus has been reached on a specific method or solution.
There is mention of a second problem involving the antiderivative of a different function, indicating that participants are navigating multiple integration challenges simultaneously. The original poster's understanding of integration appears to be developing, as they seek further clarification and hints.
beanryu
What is the integral of 110*1.10^(t) from b=35 to a=0 (b being hte upper number to the integral sign and a being the lower number to the integral sign)
From the textbook it says it's the constant c=110 times the sum of the integral of b - the integral of a.
so how do i get integral of a and b?
Thank you for replying!
You could try to make use of [tex]\exp \left( {t\log \left( {1.10} \right)} \right) = \exp \left( {\log \left( {1.10} \right)^t } \right) = 1.10^t[/tex].
Thanx Benny~! Thank You!
HEY DeAR BENNY
I got another problem if you could help again... I would really really appreciate it
10+990e^(-0.1t)
now to so far i know its antiderivative starts with
10t+ ... something... could you guys give me some hint as to how to continue?
If k is a constant then [tex]\int {e^{kt} } dt = \frac{1}{k}e^{kt} + c[/tex] where c is an arbitrary constant. Just use that to integrate the exponential. By the way, I would have thought that this one would have been very simple for you if you were able to do the first problem you asked about.
