Infinite Series: rearrangement of Terms
The discussion revolves around the properties of rearrangements of convergent series, specifically focusing on a series where terms are rearranged with the constraint that no term is moved more than two places. Participants explore the implications of this rearrangement on the convergence and equality of the sums of the original and rearranged series.
  • Bailey presents a convergent series and seeks to understand how a specific rearrangement affects its sum and convergence.
  • One participant suggests bounding the difference between the sums of the original and rearranged series, |S'_N - S_N|.
  • Bailey proposes a bound on the difference using terms from the series, leading to inequalities involving S_n and S'_n.
  • Bailey concludes that if the original series converges, then the sums of the original and rearranged series must be equal, S_n = S'_n, under certain conditions.
  • Bailey questions how to demonstrate that the rearranged series also converges.
  • A later reply prompts Bailey to consider the specific values of n for which the derived inequalities hold true.
The discussion contains uncertainty regarding the conditions under which the equality of the sums holds and whether the rearranged series converges. No consensus is reached on these points.
Participants express assumptions about the behavior of the terms in the series, particularly that a_n approaches zero as n increases. The implications of these assumptions on the convergence of the rearranged series remain unresolved.
MrBailey
Hello,
I could use a big helping hand in trying to understand an example from a text.
Let's say I have a convergent series:
[tex]S=\sum_{n=1}^{\infty}{a_n}[/tex]
Okay, so now:
[tex]\sum_{n=1}^{\infty}{a'_n}[/tex]
is a rearrangement of the series where no term has been moved more than 2 places.
So, the exercise is to show that the rearranged series has the same sum and is also convergent.
A partial sum of the original series:
[tex]S_N=a_1+a_2+\ldots +a_N = S_{N-2}+a_{N-1}+a_N[/tex]
A partial sum of the rearranged series:
[tex]S'_N=a'_1+a'_2+\ldots +a'_N = S'_{N-2}+a'_{N-1}+a'_N[/tex]
I think I need to somehow bound
[tex]S'_N[/tex]
but I'm not sure how.
Can someone steer me in the right direction?
Thanks,
Bailey
Try to bound [tex]|S'_N-S_N|[/tex]
Okay, is this on the right track?
So,
[tex]S_n = a_1 + a_2 + \ldots + a_n[/tex]
and
[tex]S'_n[/tex] is a rearrangement of the series where the terms move no more than 2 places.
Then
[tex]|S'_n - S_n| \leq |a_{n-1}| + |a_n| + |a_{n_1}| + |a_{n_2}|[/tex]
where [tex]n < n_1 < n_2[/tex]
From that we get:
[tex]S_n - (|a_{n-1}| + |a_n| + |a_{n_1}| + |a_{n_2}|) \leq S'_n \leq S_n + (|a_{n-1}| + |a_n| + |a_{n_1}| + |a_{n_2}|)[/tex]
but since the original series converges: [tex]a_n \rightarrow 0[/tex]
Therefore, [tex]S_n \leq S'_n \leq S_n[/tex] or [tex]S_n = S'_n[/tex]
Is this correct?
How do I show that the new series converges as well?
Thanks,
Bailey
What values of n do you think this equation is true?
  • · Replies 20 ·
