Inverse Polar Graph: Graphing r=ArcCos(θ)
The discussion revolves around the graphing of polar equations, specifically focusing on the inverse of the polar equation r=Cos(θ) and the implications of switching variables in polar coordinates. The original poster seeks to understand the graph of r=ArcCos(θ) and its limitations in terms of real values.
  • The original poster attempts to graph the inverse of a polar equation and questions the real number limitations of the ArcCos function. Some participants discuss the implications of the domain of ArcCos and its effect on plotting. Another participant raises a question about the inverse of a spiral graph.
Participants are exploring the properties of polar equations and their inverses. Some guidance has been offered regarding the domain of the ArcCos function, and there is an ongoing inquiry into the nature of spirals in polar coordinates. Multiple interpretations of the inverse relationship in polar graphs are being discussed.
There are constraints regarding the domain of the ArcCos function, which limits the values of θ that can be used in the graphing process. The original poster also expresses uncertainty about the real values of θ in relation to the graph of r=ArcCos(θ).
Mike AkA Don
I need to figure out what or if what I found is why it is.
I need the inverse of a polar equation graphed.
When I say inverse I mean switching the variables and then placing it in proper form again.
I have the equation r=Cos(θ) which produces the following graph.
http://images.iceogen.net/cospheta.gif
What I need is r=ArcCos(θ), when put in Mathematica it gives me this.
http://images.iceogen.net/inverse.gif
Between the left end of the line and the x and y axises multiple values of pheta exist but they are not ploted, I believe it is because they aren't real, but why? and can this be properly graphed?
Mathematicas gives me these errors:
{ArcCos[θ] Cos[θ],ArcCos[θ] Sin[θ]} does not evaluate to a pair of real numbers at θ = 1.0453537892798384
{ArcCos[θ] Cos[θ],ArcCos[θ] Sin[θ]} does not evaluate to a pair of real numbers at θ = 1.011390375748485
{ArcCos[θ] Cos[θ],ArcCos[θ] Sin[θ]} does not evaluate to a pair of real numbers at θ = 1.0036610320397505
Any answers would be much appriciated
Mathematica is correct (as it usually is). The problem is that the domain of ArcCos is [-1,1] (since the range of Cos is [-1,1]). In other words, there is no real number whose Cos is greater than 1. You can therefore only plot your equation from -1 <= theta <= 1.
-Dale
I didn't ask the right question sorry... I shouldn't have used cos... What I need to know is this...
If the graph of r=θ is a spiral, what would the inverse of a spiral look like?
To find inverses you switch variables and solve. E.g. to find the inverse of y=x^2 you switch variables x=y^2 and solve for y to get y=x^(1/2). Same thing here, you switch variables θ=r and solve for r to get r=θ. So, in polar coordinates, the spiral r=θ is its own inverse, just like the line y=x is its own inverse.
-Dale
You can use graphmatica ( <-feel lucky & google on ) for these quick-plot purposes
  • · Replies 18 ·
18K
