What Are the Quantum Forces Behind Diffusion Phenomena?
  • Context: Graduate
  • Thread starter Thread starter Wishbone
    Diffusion
The discussion focuses on the quantum forces and mechanisms underlying diffusion phenomena, particularly in the context of gas molecules and their behavior at the atomic level. Participants explore the relationship between pressure differences and molecular movement, as well as the random walk nature of diffusion.
  • One participant expresses confusion about the quantum forces involved in diffusion and how pressure differences relate to molecular movement.
  • Another participant explains diffusion as a random walk phenomenon, describing how gas molecules collide and change direction frequently, leading to eventual detection of scents.
  • A question is raised regarding the dependence of fragrance particle velocity on atmospheric pressure and the relationship between pressure differences and particle movement speed.
  • A response clarifies that the rate of travel of cologne molecules toward a destination is influenced by the density of air molecules present, and that a density gradient affects the frequency of molecular movement between regions of different densities.
Participants do not reach a consensus on the quantum forces behind diffusion, and multiple viewpoints regarding the relationship between pressure, density, and molecular movement are presented.
The discussion includes assumptions about the behavior of molecules in different pressure and density conditions, but these assumptions are not explicitly stated or resolved.
Wishbone
This phenomina I really don't undertsand. I know that a difference in 2 pressures will cause a force through P= F/A, but what I want to know is, what is type of force of it, what's going on, on the quantum level?
Diffusion isn't so much a pressure driven phenomenon as it is a random walk phenomenon. At the atomic level, a gas has atoms or molecules each at a specific location and with a specific velocity. It doesn't take much time for any of them to bump into another. When that happens, the atom or molecule changes direction. This process repeats over and over.
So, for example, I open my bottle of cologne and set it on the counter. Some of the molecules head straight out into the air. They don't travel very far before changing direction because they collide with the air molecules. After billions of deflections left and right, forward and back, up and down a few of them finally make their way to my olfactory nerves and I detect the fragrance.
so why would the velocity of those fragrance particles depend on the pressure of the atmopshere. Or in general terms, how come the larger that pressure difference the quicker the particles move.
Those are two different questions.
For the first question, the rate at which the cologne molecules travel toward the "destination" depends on how many molecules of air there are in between.
And for the second question, you're really asking about the density of cologne molecules. If there is no gradient in the density of cologne molecules then the average rate at which one small region of space sends cologne molecules to, say, a neighboring region of space is exactly the same as the rate at which molecules from the second region are transported to the first.
In the presence of a density gradient of cologne molecules, molecules from a denser region will, on average, enter a region of lower density more frequently than those going from the lower density region to the higher density region.
  • · Replies 46 ·
