K cannot be what, if you want this matrix to form a basis, confused
The matrix given by the rows 4 -4 4, -5 6 -3, and 0 4 k can form a basis for R^3 if and only if k is not equal to 0. The row reduction process confirms that the first two columns are linearly independent, resulting in a row echelon form of 1 0 0, 0 1 0, 0 0 0. To determine the value of k without manual row reduction, one must ensure that the last column can yield a non-zero vector when solving Mx=0, specifically aiming for a solution that does not lead to a trivial case.
  • Understanding of linear independence in matrices
  • Familiarity with row reduction techniques
  • Knowledge of basis concepts in vector spaces
  • Ability to solve linear equations involving parameters
  • Study the criteria for linear independence in matrices
  • Learn about row echelon form and its applications in linear algebra
  • Explore the implications of parameters in matrix equations
  • Investigate the concept of spanning sets in vector spaces
Students and professionals in mathematics, particularly those studying linear algebra, matrix theory, and vector spaces, will benefit from this discussion.
mr_coffee
-5 6 -3
0 4 k
form a basis for R^3 if and only if k != ?
since the last col has a k in it, i wanted to see if the first 2 colmuns are linear indepdant, adn they are, because i row reduced w/calculator:
4 -4 0
-5 6 0
0 4 0
and got
1 0 0
0 1 0
0 0 0
is there a quick way to figure out the k, without mantually row reducing with k? Also if there isn't a quick way, what am i going to be looking for? it will span R^3 if i get
for the last col with k in it. Thanks.
You don't *have* to get down to 1's, merely linearly independent rows/cols, 1s are just nice. And it's better if you say "when do the rows/cols form a basis", rather than "when is the matrix a basis of R^3": the matirx is never a basis of R^3; it isn't even an element of R^3.
Remember, you're just looking for a solution of Mx=0 to imply x=0, so that's an easy criterion to check when there is only 1 variable (k) to check
  • · Replies 16 ·
