Central Force II: Find F(r) & Closest, Furthest Distances
The discussion revolves around the motion of a particle in a central force field, specifically analyzing the relationship between the radial distance \( r \) and the angle \( \theta \) given by the equation \( r = \frac{A}{1+\sin(\theta)} \). Participants are tasked with determining the form of the central force \( F(r) \) and identifying the closest and furthest distances from the origin of the force.
  • Participants explore the relationship between \( \theta \) and \( r \) to find minimum and maximum distances. Questions arise regarding the assumptions about the constant \( A \) and the behavior of \( r \) as \( \sin(\theta) \) approaches its limits.
The discussion is active, with participants questioning the correctness of their calculations and interpretations of the minimum and maximum distances. Some guidance is offered regarding the behavior of \( r \) as \( \sin(\theta) \) approaches -1, but no consensus has been reached on the correct values for the closest and furthest distances.
There is uncertainty regarding the value of \( A \) and its implications for the distances being calculated. Participants are also grappling with the mathematical implications of the denominator approaching zero in the context of the equation for \( r \).
Nusc
The orbit of a particle in a central field is known to obey the following relationship:
r = A/(1+sin(theta))
a) determine the form of the central force F(r) that is responsible for this motion.
b) What is the distance of closest approach between the particle and the point that acts as the origin of the force? What is the furthest distance that the particle can be found form the origin of the force?
a) After applying the equation of motion, you get f(r) = -(A^3*l^2*m)/r^2
But for part b, how do I find the r-min?
Also A is not mentioned as a constant so do I assume it is?
For part b,
You have
[tex]r(\theta)=\frac{A}{1+\sin \theta}[/tex]
So for what value of [itex]\theta[/itex] is r minimum and what is the minimum value?
HINT: You know [itex]\sin \theta[/itex] can only take values between -1 and 1.
R is min at theta = -pie/2, therefore R = 0
R is max at theta = pie/2, therefore R = A/2
Is this correct?
Is this correct?
No, it is not correct.
When [tex]\theta = \frac{-\pi}{2}[/tex], [itex]\sin \theta[/itex] is minimum (-1).
Now,
[tex]r = \frac{A}{1+\sin \theta}[/tex]. So 'r' will not be 0 when [itex]\theta = \frac{-\pi}{2}[/itex].
Okay so R is minimum when theta is equal to pie/2, thus A/2
But R is max when theta is equal to pie, thus R max = A ?
Nusc,
What is the value of [itex]r[/itex] when [tex]\theta = -\frac{\pi}{6}[/tex] ?
Compare this value to your "r max".
Can you now figure out what happens to [itex]r[/itex] as [tex]\sin \theta[/tex] approaches [itex]-1[/itex]?
My bad, so when theta = -pie/6 Rmax = 2A
When theta = pie/2 R min=A/2
Can you now figure out what happens to r as sin(theta) approaches -1 ?
sin(theta) = -1 if theta is equal to -pie/2
R = A/(1 + sin(-pie/2)) = A/(1-1) = A/0
How can r not be zero?
No, that's not right at all.
I did not say A/0 (Which is not 0). I meant as the denominator approaches 0 (ie, really close to 0 but not 0).
What is the value of the fraction as the denominator approaches 0? Try using a calculator to find this value for smaller and smaller values of the denominator. Can you see any relation?
