How Does a Voltage Tester Work?
  • Thread starter Thread starter omul_b
The discussion revolves around the operation of a voltage tester, specifically a type of circuit tester that lights up to indicate the presence of voltage. Participants explore the underlying principles of how the device functions, including the role of body capacitance and the type of bulb used, while also addressing related concepts of capacitors and current flow in circuits.
  • One participant describes the voltage tester as a screwdriver with a light bulb that indicates voltage presence when plugged into an outlet.
  • Another participant suggests that the tester likely uses a gas-discharge bulb and requires grounding, but expresses uncertainty about this claim.
  • It is proposed that a neon bulb is used in the tester, with the body completing the circuit back to ground.
  • A participant challenges the idea that the tester uses a neon bulb, asserting it appears to be an ordinary light bulb instead.
  • One participant notes that wearing rubber boots affects the brightness of the light, indicating a connection to body capacitance.
  • Questions are raised about the human body acting as a capacitor and whether the tester would light up if isolated from the ground.
  • Another participant explains that capacitors can conduct current from AC sources and that the body and ground can act as the two sides of a capacitor.
  • A separate inquiry about how capacitors complete a series circuit leads to a discussion on current flow in resistor-capacitor circuits.
Participants express differing views on the type of bulb used in the tester and the necessity of grounding. There is no consensus on the exact mechanism of operation, particularly regarding the role of body capacitance and the behavior of capacitors in circuits.
Some participants mention the need for grounding and the effects of body capacitance, but these concepts remain unresolved in terms of their implications for the voltage tester's operation. The discussion also touches on the behavior of capacitors in circuits, which introduces additional complexity.
omul_b
Ciao all. I have kind of a basic question but i don't really understand how it works. I don't know how it's named in english, but maybe "voltage controller". It's a screwdriver with a small light bulb that is used to see if there is voltage, on an outlet for example. You plug it into the "phase"(hot) wire hole and press your thumb against a metalic end at the end of the handle and if there is voltage the bulb lights up. So here's the question, how does it work? how do you complete the circuit. Maybe a small schematic please. I know it may be a simple question so pleasez enlighten me! 10x
Welcome, Omul_b.
We just call those circuit testers. I've worked only with DC ones, and they have to be grounded. All that I can think of in the case that you're talking about is that it must be some sort of gas-discharge bulb that lights when it's in an EM field and modified by body capacitance. I really don't know, though.
It is most likely a neon bulb inside the tester. Either the body capacitance or the actual path back through ground completes the circuit.
I don't know about DC ones, but this one is not grounded, and it isn't a neon bulb (or i don't think so). It just looks like an ordinary light bulb. I still don't understand. Anyone ??
I SERIOUSLY doubt it is a regular incandescent bulb.
Look at the glass bulb and see if there are two small, parallel electrodes inside. If so, it's a neon buld and works as Averagesupernova says where you body completes the path back to ground. The current through the circuit is very small but the potential difference across the two electrodes causes the neon to glow.
Regards
I noticed that if i wear rubber boots on my feet the light is not that strong (BTW you were right, it's a neon bulb). And, for that matter, please tell me:
1) I've heard a lot of stuff about the human body behaving like a "capacitor". How does this happen ? I mean if you connect a capacitor at one end of a circuit it wouldn't gather anything, would it? I mean there is no voltage across it. It's just like the birds standing on the electrical wire.
2) If i were perfectly isolated from the ground, would it light up ?
10x in advance and sorry about all the questions :)
Capacitors conduct current from A.C. sources. Your body is one side of the cap and the ground is the other.
brief question in between~~
How does a capacitor complete a series circuit?
both sides of the capacitor is not connected... how does electrons flow? or does it even flow across the capacitor?
if a battery positive terminal is connected to a resistor, then the resistor is connected to a capacitor, which is connected back to the negative terminal of the battery, would there be current through the resistor?
sorry for the interruption~
You should start a new thread on this.
In a resistor-capacitor charging circuit, capacitor voltage goes from nothing to full source voltage while current goes from maximum to zero, both variables changing most rapidly at first, approaching their final values slower and slower as time goes on. Current through the circuit is determined by the difference in voltage between the battery and the capacitor, divided by the resistance. As the capacitor voltage approaches the battery voltage, the current approaches zero. After a capacitor has fully charged (to the level of the volatge source), it acts as a open circuit (voltage drop with no current)
  • · Replies 32 ·
