| Thread Closed |
Calculations of Solubility Product of Lead 2 Chloride |
Share Thread | Thread Tools |
| Dec18-05, 09:09 PM | #1 |
HELP! In this experiment I measured the initial mass of a piece of Al and then i put it into a beaker containing 100.0 mL of saturated PbCl2
The concentration I calculated for Pb is [tex] 6.12 *10^-^5 [/tex] mol/L The concentration I calculated for Cl is [tex] 1.224* 10^-^4 [/tex] mol/L Therefore my Ksp= [Pb] [Cl]^2 [tex] =[6.12*10^-^5] [1.224*10^-^8]^2 [/tex] Ksp=9.17 This is what I calculated please verify I need help answering this question if 100.0 ml of 0.02 mol/L lead 2 nitrate solution and 100.0 ml of 0.02 mol/L sodium chloride solution were combined would a precipitate of Lead 2 chloride be expected to form? I have to show all my work. But im not sure where to start. |
| Dec18-05, 11:05 PM | #2 |
G'day, Aisha.
The first part of your post is a little confusing. How did you calculate [Pb2+] and [Cl-]? If these concentrations are indeed in a saturated solution then Ksp(PbCl2) = 9.16x10^(-13), just a couple of typos there. At 25 degrees C, the Ksp of PbCl2 is about 1.6x10^(-5), so perhaps the room was cold? If the second part is connected to the first part, then you are probably to find the ionic product (given by [Pb2+][Cl-]^2) and compare it to the Ksp value obtained earlier. Hint: for the same amount, doubling the volume halves the concentration. If IP > Ksp, a precipitate will form. ~ ~ ~ ~ ~ ~ I'm new here but I think this belongs in the Science Education forum. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculations of Solubility Product of Lead 2 Chloride
| Solubility of lead (II) chloride | Biology, Chemistry & Other Homework | 1 | ||
| [SOLVED] Solubility Thallous Chloride | Biology, Chemistry & Other Homework | 6 | ||
| [SOLVED] equilibirum and solubility product | Biology, Chemistry & Other Homework | 2 | ||
| solubility product | Biology, Chemistry & Other Homework | 7 | ||
| HELP solubility product determine solubility of lead 2 chloride mol/L and g/L | Biology, Chemistry & Other Homework | 2 | ||
