Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image The Foundations of Relativity Share It Thread Tools Search this Thread image
Old Dec20-05, 03:58 AM       Last edited by Oxymoron; Dec20-05 at 04:05 AM..            #1
Oxymoron
Oxymoron is Offline:
Im trying to understand more about the foundations upon which general relativity lies.
The first thing I need to clarify is the space in which GR works. I've read that GR merges time and space into spacetime, which to my understanding means that, when considered separately, time and space are invariant.
This spacetime must then be much like any other mathematical space, such as Euclidean space or Hilbert space, in that notions of distance must be defined.
In Euclidean space, LaTeX Code: \\mathbb{R}^3 , you have the Euclidean metric,
LaTeX Code: \\Delta s^2 = x^2 - y^2
which obeys all the axioms of a metric and defines the distance between two points in the Euclidean space.
However, I have read, that the metric in spacetime, the spacetime metric, is defined as
LaTeX Code: \\Delta s^2 = \\Delta x^2 + \\Delta y^2 + \\Delta z^2 - c^2 \\Delta t^2
This spacetime metric raises some issues with me. If this is the metric of spacetime then points in spacetime must be represented as a 4-vector. Are these points actually called events by physicists?
The Euclidean plane has structure, right, in the form of the Euclidean metric:
1. LaTeX Code: d(x,y) \\geq 0
2. LaTeX Code: d(x,y) = 0 \\Leftrightarrow x = y
3. LaTeX Code: d(x,y) = d(y,x)
4. LaTeX Code: d(x,z) \\leq d(x,y) + d(y,z)
In a similar fashion I am interested to know what the structure on spacetime is? Are there similar axioms for the spacetime metric?
Old Dec20-05, 06:28 AM                  #2
Oxymoron
Ok, maybe I jumped in too quickly for myself.
In Euclidean space, LaTeX Code: \\mathbb{R}^3 , you have the distance metric between any two pairs of points to be
LaTeX Code: \\Delta s^2 = (\\underline{x}_2 - \\underline{x}_1)^2
Then you can construct Euclidean transformations, where the distance is invariant, resulting in what are called affine transformations. I learnt that tranformations can be expressed by matrices. So, such a Euclidean transformation can be expressed like
LaTeX Code: \\Delta \\underline{x}single-quote = A\\Delta \\underline{x}
So the 'transformed' vector equals the product of some matrix pertaining to the transformation and the original vector. Then by letting one of the pairs of points be the origin you can get
LaTeX Code: \\underline{x}single-quote = A\\underline{x} + a
where LaTeX Code: a is some constant.
Now the problem I have comes when I take this one step further. Consider Galilean space. I have found that it has some structure; three axioms:
1. Time Intervals LaTeX Code: \\Delta t = t_2 - t_1
2. Spatial Distance LaTeX Code: \\Delta s = |\\underline{x}_2 - \\underline{x}_1|
3. Motions of inertial particles (rectilinear motion) LaTeX Code: \\underline{x}(t) = \\underline{u}t + \\underline{x}_0
And by a similar method done in Euclidean space you can see that
LaTeX Code: tsingle-quote = t + a
LaTeX Code: \\underline{x}single-quote = A\\underline{x} - \\underline{v}t + \\underline{b}
BUT, why don't Galilean transformations preserve the light cone at the origin? Why must we formulate the Minkowski metric to take care of this?
Old Dec20-05, 11:41 AM                  #3
selfAdjoint
selfAdjoint is Offline:
Recognitions:
PF Contributor PF Contributor
Retired Staff Retired Staff
The metric you cite is actually that of "flat" Minkowski space of special relativity, not the more general metric of Einstein's pseudo-Riemannian manifold. From the Minkowski metric you can define the causal structure ("light cones") of his spacetime and then define the Lorentz transformations as the set of linear transformations the leave that metric invariant.
To do the pseudo-Riemannian geometry you need a more general metric, a symmetric tensor LaTeX Code: g_{\\mu\\nu}, \\mu, \\nu = 0,...,3 . From the derivatives of this wrt the coordinates you define the Levi-Civita Connection LaTeX Code: \\Gamma^{\\rho}_{\\sigma\\tau} , then the covariant derivative and finally the curvature tensor. This is not too difficult to grasp, but you really should read up on manifolds first.
Old Dec20-05, 01:53 PM       Last edited by robphy; Dec20-05 at 01:55 PM..            #4
robphy
robphy's Avatar
robphy is Offline:
Recognitions:
Homework Helper Homework Helper
Why? They just don't. The eigenvectors of the Galilean transformation are purely spatial vectors. For Galilean, this means that t=constant...which means that there is a notion of absolute time and absolute simultaneity. On the other hand, the eigenvectors of the Lorentz Transformation (which preserve the Minkowski metric) are lightlike vectors that are tangent to the light cone... which means that the speed of light is absolute.
Old Dec21-05, 12:11 AM       Last edited by Oxymoron; Dec21-05 at 12:47 AM..            #5
Oxymoron
Ok, so obviously Galilean spacetime works fine for classical mechanics but not for special relativity. Am I correct to assume that the spacetime interval
is the metric in Minkowski space? The way I see it is that this way of defining the distance between two events (points) in Minkowski space also incorporates the time interval between the two as well.
When events satisfy LaTeX Code: \\Delta s^2 = 0 then we say that they are connected by a light signal?
It seems to me that by introducing the Minkowski metric we have combined space and time into spacetime and yet we have split spacetime, via the light cone from an event, into two pieces: one which is cut off from the event (by the absolute speed of light) and one which recieves information about the event (from the transmission of the light signal).
A problem I am having is visualising the light cone. If I create an event, say I create a photon. Then the photon spreads out from where it is created in all three spatial directions at the speed of light. Im not sure if this is right, but I tend to imagine the point of origin (the tip of the cone) as where I created the photon. In space the light spreads out as a sphere until it consumes the entire universe. Points in space outside the sphere do not know of what is happening inside the sphere until it reaches that point and that time is restricted by the speed of light. But this notion is spherical, not conical.
EDIT:
Im babbling here. Surely light cones are 4-dimensional and I am trying to picture them as 3-dimensional objects on 2-dimensional paper so clearly Im getting the wrong impression. If anyone has a good description of them or knows of any I would be appreciative.
Why? They just don't. The eigenvectors of the Galilean transformation are purely spatial vectors. For Galilean, this means that t=constant...which means that there is a notion of absolute time and absolute simultaneity. On the other hand, the eigenvectors of the Lorentz transformation (which preserve the Minkowski metric) are lightlike vectors that are tangent to the light cone... which means that the speed of light is absolute.
The eigenvectors of the Galilean transformation. The Galilean transformations are
LaTeX Code: \\underline{x}single-quote = A\\underline{x} + \\underline{a}(t)
right? I played around with Newton's first law of motion I came to the conclusion that A is a constant matrix, that is, its time-derivatives are all zero. What could this mean? Well, I read what you wrote and it makes sense - I hope! - the eigenvectors of the Galilean transformation are indeed spatial. Using the Galilean transformations on Newton's First Law of motion there is absolute time and simultaneity. If this is the case then how can an event behave as it does in special relativity? Is this why the Galilean transformation does not preserve the light cone?
If so, changing to the Lorentz transformation
LaTeX Code: \\underline{x}single-quote = L\\underline{x} + \\underline{a}(t)
tells me that the space is affine. (not sure about this).
My question at this stage is, does the Lorentz transformation preserve the light cone at any event?
Old Dec21-05, 07:53 AM                  #6
Oxymoron
I finally discovered the true definition of Minkowski spacetime - in terms of the metric defined on it. Please correct me if any of my understanding is flawed. The metric is a nondegenerate, symmetric, indefinite, bilinear form:
LaTeX Code: \\bold{g} : \\mathscr{M} \\times \\mathscr{M} \\rightarrow \\mathbb{R}
Within Minkowski spacetime we may define the Lorentz inner product as being
LaTeX Code: g(v,w) := v\\cdot w = v_1w_1 + v_2w_2 + v_3w_3 - v_4w_4
Once we include the inner product does Minkowski spacetime become an inner product space, you know, like Hilbert space?
Vectors in LaTeX Code: \\mathscr{M} are either spacelike, timelike, or null if the inner product is positive, negative, or zero respectively.
Now lets collect all the null vectors into one set and call it the null cone, or light cone:
LaTeX Code: C_N(x_0) = \\{x\\in\\mathscr{M} \\,:\\, v\\cdot w = 0\\}
So the light cone is a surface in Minkowski space consisting of all those vectors whose inner product with LaTeX Code: x_0 is zero. The Lorentz inner product tells us the spacetime interval between two events right? If the inner product, LaTeX Code: g(v,x_0) is zero then the spacetime interval between the event LaTeX Code: v and LaTeX Code: x_0 is simultaneous. Therefore the light cone is the collection of events in spacetime which occur simultaneously to an observer at LaTeX Code: x_0 .
If I spontaneously create a photon and call the event LaTeX Code: x_0 then the photon radiates outward in all spatial directions. I should be able to construct a light cone whose point is at LaTeX Code: x_0 .
All the events inside the future light cone of the event happen AFTER the event - there is a strict time ordering of events inside the future cone. We can even say that the event LaTeX Code: x_0 can cause things to happen, and if it does the new event must be within the future cone. So events which are caused by LaTeX Code: x_0 must be reachable by information at speeds less than LaTeX Code: c . We then say that these new events are caused by LaTeX Code: x_0 and are timelike vectors.
If the new events inside the future light cone are all timelike then their Lorentz inner product must be negative. But what does this mean? If the Lorentz inner product is meant to tell us the spacetime interval between two events, and this interval is negative, does it mean that the new event (caused by LaTeX Code: x_0 and thus inside the future light cone) is further away from LaTeX Code: x_0 in time than in space?
Old Dec21-05, 09:07 AM       Last edited by robphy; Dec21-05 at 09:48 AM..            #7
robphy
robphy's Avatar
robphy is Offline:
Recognitions:
...where the rightmost expression uses rectangular components and the (+,+,+,-) signature convention.
...inner product with itself (that is, its square norm) is...
...the null vectors at a point (event) [say, LaTeX Code: x_0 ] of M.
It's not "all those vectors whose inner product with LaTeX Code: x_0 "... but "all those vectors at event LaTeX Code: x_0 whose inner product with itself "...
Old Dec21-05, 09:47 AM                  #8
robphy
robphy's Avatar
robphy is Offline:
Recognitions:
There may be some confusion here. The arguments of the metric are vectors. So, when you write LaTeX Code: g(v,x_0) , then v and x_0 are vectors. However, x_0 is a point (event)... unless you somehow want to use something like a so-called position vector in spacetime... however, you now have to specify an origin of spacetime position... but then your inner product LaTeX Code: g(v,x_0) depends on that choice of origin... probably not what you want.
"That two events are simultaneous" is an observer dependent concept. Using your something similar to your notation LaTeX Code: g(v,x_0) , I can clarify this.
At event x_0, let v be a unit-timelike vector (representing an observer's 4-velocity). Suppose there is an event x_1 such that the displacement vector LaTeX Code: \\Delta x=x_1-x_0 has inner-product zero with v: LaTeX Code: g(v,x_1-x_0) ... then x_1 and x_0 are simultaneous according to the observer with 4-velocity v. Looking at this in more detail, the 4-vector LaTeX Code: \\Delta x=x_1-x_0 must be a spacelike vector... to observer-v, it is in fact a purely spatial vector... in other words, it is orthogonal to v.
So, "Therefore the light cone is the collection of events in spacetime which occur simultaneously to an observer at LaTeX Code: x_0 " is NOT correct.
In Minkowski space, the future light cone traces out the set of events that can be reached by a light signal at the vertex event (what it broadcasts)... the past light cone traces out the events that reach the vertex event by a light signal (what it literally "sees").
I would probably say "a flash of light"..."sending out many photons outward
in all spatial directions".
I would say "can be influenced by LaTeX Code: x_0 "... since an event P can be influence by many events (not just LaTeX Code: x_0 ) in the past light cone of P.
Again... you need to distinguish points (events) from vectors.
Old Dec21-05, 08:09 PM                  #9
Oxymoron
here may be some confusion here. The arguments of the metric are vectors. So, when you write , then v and x_0 are vectors. However, x_0 is a point (event)... unless you somehow want to use something like a so-called position vector in spacetime... however, you now have to specify an origin of spacetime position... but then your inner product depends on that choice of origin... probably not what you want.
So we must treat events differently to these timelike and spacelike vectors? Or is it simply that the two do not compute right in the metric? Im confused at why the event, LaTeX Code: x_0 is not a vector in Minkowski space? Wait, maybe not. Elements of Minkowski space are events; vectors in Minkowski space are not events, right?
That two events are simultaneous" is an observer dependent concept. Using your something similar to your notation , I can clarify this.
At event x_0, let v be a unit-timelike vector (representing an observer's 4-velocity). Suppose there is an event x_1 such that the displacement vector has inner-product zero with v: ... then x_1 and x_0 are simultaneous according to the observer with 4-velocity v. Looking at this in more detail, the 4-vector must be a spacelike vector... to observer-v, it is in fact a purely spatial vector... in other words, it is orthogonal to v.
So, "Therefore the light cone is the collection of events in spacetime which occur simultaneously to an observer at " is NOT correct.
Is v inside the future light cone? Surely it must be outside the cone? In which case, no matter what the 4-velocity of the observer, so long as it is spacelike, will see LaTeX Code: x_0 and LaTeX Code: x_1 simultaneously.
At this point I was about to ask "What if the observer was inside the cone, whose 4-velocity was purely time-like. Would the two events appear simultaneous now?". Surely, LaTeX Code: \\bold{g}(v,\\Delta x) is still zero, so the events are on the surface of the light cone, but now the observer must see one event happen AFTER the other. If this is right, could you explain.
One extra question. What is LaTeX Code: \\eta_{ab} , the thing which can be 1, -1, or 0 depending on a and b.
Old Dec21-05, 08:32 PM       Last edited by dicerandom; Dec21-05 at 08:35 PM..            #10
dicerandom
dicerandom is Offline:
Correct. Events are points in the Minkowski space, vectors (can) connect events.
v must be in the light cone, otherwise the velocity would be greater than that of light. In order for two events to be seen simultaneously they must have a purely spatial seperation in the observer's refrence frame, as robphy said the vector connecting the events must be normal to the world line (the velocity vector) of the observer. If we restrict ourselves to 1D motion there will only be one velocity which will see two spacelike seperated events as simultaneous. Events which are not spacelike seperated cannot be seen as simultaneous by any observers.
I don't see how LaTeX Code: \\bold{g}(v,\\Delta x) could be zero if the two events are on the lightcone. LaTeX Code: \\bold{g}(\\Delta x,\\Delta x) would be zero since they're lightlike seperated, but v is a different vector.
LaTeX Code: \\eta_{\\mu \\nu} is the metric of flat Minkowsky space, it's diagonal and all 1's in the diagonal slots, except for the -1 in the time position (either the upper left or bottom right, depening on which book you're looking at). Note that by convention greek indicies imply a range over all four dimensions whereas roman indicies imply a range over only the spatial dimensions.
Old Dec21-05, 09:51 PM                  #11
Oxymoron
Hmmm, Im still confused.
If we have an event LaTeX Code: x_0 from which we construct a light cone then future events which occur on the surface of the light cone have Lorentz inner product zero. Future events which are inside the cone are connected by time-like vectors, and those outside are connected by space-like vectors.
Right so far? (probably not)
My question here is: how do I define an observer? Can he be anywhere - as in, inside the cone, outside, at the event? I mean, could an observer be at the very location of the event at the time it occurs? Or could he be in the event's future - perhaps on the surface of the light cone or inside it or outside it.
Old Dec21-05, 09:59 PM                  #12
robphy
robphy's Avatar
robphy is Offline:
Recognitions:
An observer's 4-velocity v is a unit-timelike vector tangent to the observer's worldline. It points into the interior region enclosed by the future light cone (the "chronological future" of the vertex event). One can roughly interpret v as one unit of time along that observer's worldline. So, the 4-velocity v is never spacelike [and never null].
Old Dec21-05, 10:05 PM                  #13
Oxymoron
Posted by Dicerandom
So that is why the null vectors are sometimes called lightlike vectors!! Because for v was on the surface then v = c and all of a sudden every event in the future is simultaneous to that observer. v cannot be outside the cone because then v > c.
Old Dec21-05, 10:11 PM                  #14
Oxymoron
If I cause an event LaTeX Code: x_0 and I am the observer at that point. Then can I safely say that there is a future event LaTeX Code: x_1 which lies on the light cone of the original event? To me, if there is such an event and LaTeX Code: x_0 causes that event to occur, then my velocity must be c. Since my 4-vector is timelike and if I observe LaTeX Code: x_0 causing LaTeX Code: x_1 (which is on the surface) then my velocity is c.
Old Dec21-05, 10:17 PM       Last edited by dicerandom; Dec21-05 at 10:19 PM..            #15
dicerandom
Looks good so far
The observer can be anywhere, yes. However what we generally do is define a worldline for an observer, i.e. a path that the observer will follow through spacetime. In simple cases the observer has constant velocity and it's just a straight line, however in more complicated situations the observer can undergo accelerations and the worldine can be curved. At any point along the worldline we define what is called the MCRF (Momentarily Comoving Reference Frame), which is a reference frame that is moving with uniform velocity equal to the instanteneous velocity of the observer. The observer's velocity vector is then the unit vector which points along the time axis of this reference frame, i.e. it is a vector of unit length which is tangental to the observer's worldline.
Right I'd be careful about saying what happens when v=c though, technically the theory doesn't extend to that point but if you look at the limiting behavior as v->c that is how it seems things would be.
There are in fact an infinite number of such events. Suppose that you're out in space with a flashlight, you turn your flashlight on and some time later a friend who is some distance away sees that you turned your light on. You turning your light on would be your event LaTeX Code: x_0 and your friend seeing the light would be an event LaTeX Code: x_1 which lies on the lightcone from LaTeX Code: x_0 , yet you didn't have to move anywhere.
Old Dec21-05, 10:31 PM                  #16
Oxymoron
There are in fact an infinite number of such events. Suppose that you're out in space with a flashlight, you turn your flashlight on and some time later a friend who is some distance away sees that you turned your light on. You turning your light on would be your event and your friend seeing the light would be an event which lies on the lightcone from , yet you didn't have to move anywhere.
...if you were moving at v = c, would you know instantly that your friend saw your light flash - instead of some time later? To me it seems that the time it takes for information to get around inside the light cone depends on the observer's velocity too?
Also, just say that you were that friend, waiting for me to flash the light. At time=0 you must clearly be outside the cone. Is this the reason why the light cone is hard to picture, because in 3 dimensions you dont realize that the cone itself is 'expanding' - that is, this expanding in time dimension is compressed. Because an observer who at LaTeX Code: t = t_1 observes the initial event (and therefore at this time inside the cone) is outside the cone initially.
image image
Reply
Thread Tools
Similar Threads for: The Foundations of Relativity
Thread Thread Starter Forum Replies Last Post
foundations of mathematics ehrenfest Academic Guidance 5 Mar31-08 05:51 PM
Mathematical Foundations of QM curtvon@googlemail.com Math & Science Software 11 Aug7-07 06:00 AM
Foundations of chemistry pivoxa15 Chemistry 1 Mar31-07 10:53 PM
The Foundations of Relativity II Oxymoron Special & General Relativity 17 Jan18-06 05:10 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
