Visualizing Level Curves of f(x,y) = sin(2phi)
  • Thread starter Thread starter Benny
    Curves
The discussion revolves around visualizing the level curves of the function f(x,y) = 2xy/(x^2 + y^2) and its representation in polar coordinates as f(r*cos(φ), r*sin(φ)) = sin(2φ). Participants are exploring the implications of setting f equal to a constant and the resulting shapes of the level curves.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conversion to polar coordinates and its impact on understanding the level curves. There are questions about the range of values for which level curves can be defined, particularly regarding the limits of c based on the function's behavior.
Some participants have offered insights into the mathematical relationships governing the level curves, noting that for certain values of c, the curves can be represented as straight lines. There is ongoing exploration of the implications of these findings, particularly concerning the constraints on c.
Participants note that the family of level curves is only meaningful for -1 ≤ c ≤ 1, as derived from the properties of the function. There is also mention of the need to avoid division by zero when considering specific values of c.
Benny
Hi, I'm having trouble drawing the level curves of a function because I can't really visualise what's going on.
[tex] f\left( {x,y} \right) = \frac{{2xy}}{{x^2 + y^2 }}[/tex]
In polar coordinates (x,y) = (rcos(phi),rsin(phi)) I get:[tex]f\left( {r\cos \phi ,r\sin \phi } \right) = \sin \left( {2\phi } \right)[/tex].
Level curves are obtained by setting f equal to a constant. In the case of a circle for example f(x,y) = x^2 - y^2 - 9 if I set f(x,y) = k where -9 < k <= 0, in the x-y plane I get level curves which are circles with radii between 0 and 3 (3 inclusive).
I'm not sure which happens here though. I have f(polar) = sin(2phi) where phi is the polar angle. Since, 1- <= sin(x) <= 1 then does that mean I can only set f equal to values in the range [-1,1]?
I'm still not really sure what the level curves should be like. Any help would be good thanks.
Do you have a particular reason for converting to polar coordinates?
Level curves are points (x,y) that give f(x,y) a constant value:
[tex]f(x,y)= \frac{2xy}{x^2+y^2}= c[/tex].
That is the same as 2xy= c(x2+ y2 or
x2+ (2/c)xy+ y2= 0. Obvious point: if c= 1 that is
x2+ 2xy+ y2= (x+ y)2= 0 which is the single straight line y= -x. It should be easy to show that for other values of c, it can still be factored and the graph will be two straight lines intersecting at (0,0).
[itex]f(x,y)= \frac{2xy}{x^2+y^2}= c\Rightarrow y^2-\frac{2xy}{c}+x^2= 0[/itex], which is quadratic in y, hence
[tex]y=\frac{ \frac{2x}{c} \pm\sqrt{ \left( \frac{2x}{c}\right) ^2 - 4x^2} }{2}[/tex]
Converting to polar coordinates just seemed to simplify the expression. I'll have another look at it. Thanks for the help.
A little more detail...
[tex]y=\frac{ \frac{2x}{c} \pm\sqrt{ \left( \frac{2x}{c}\right) ^2 - 4x^2} }{2} = \frac{x}{c}\left( 1\pm\sqrt{1-c^2}\right)[/tex]
note that this family of level curves given by [itex]f(x,y)=c[/itex] is only meaningful for [itex]-1\leq c\leq 1[/itex]. This is because, for every [itex](x,y)\in \mathbb{R} ^2[/itex], we have
[tex]0\leq (x - y)^2 =x^2 - 2xy + y^2 \Rightarrow 2xy\leq x^2 + y^2 \Rightarrow f(x,y)= \frac{2xy}{x^2+y^2} \leq 1[/tex]
and
[tex]0\leq (x + y)^2 =x^2 + 2xy + y^2 \Rightarrow -2xy\leq x^2 + y^2 \Rightarrow -1\leq\frac{2xy}{x^2+y^2} =f(x,y)[/tex]
thus
[tex]f(x,y)= \left| \frac{2xy}{x^2+y^2} \right| \leq 1[/tex]
so no other values of c are even possible (except c=0) and we thereby gain assurence that our family of curves is complete. The plot below shows 7 level curves superimposed on the plot of f(x,y) over -3 < x < 3, -3 < y < 3 .
For c=0, we get 2xy=0, so either x=0 or y=0, but not both, as that would involve division by zero, and so among our level curves, count also the x-axis & the y-axis less the origin.
Thanks again for your help. I'll go over your work after I get some sleep.:zzz:
I too will go over my work after I get some sleep. So be careful if you get up before me.
and
thus
In other words, if c= 0, the level curve is a single straight line through the origin and for other values of c, the level curve is two straight lines passing through the origin, as I said above.
  • · Replies 20 ·
