How Does Blocking with Serum Work Before Antibody Hybridization?
  • Thread starter Thread starter Monique
The discussion focuses on the mechanism of blocking with serum before antibody hybridization in immunological assays. The blocking agents, such as serum albumin, skim milk, or Tween, coat the proteins or surfaces to prevent nonspecific binding while allowing specific antibody interactions. Key factors influencing binding stringency include pH, salt concentration, and the concentration of the blocking agent. It is established that a properly chosen blocking agent does not interfere with the specific binding of antibodies, provided that the affinity of the antibody is sufficient.
  • Understanding of immunological assays and antibody hybridization
  • Knowledge of blocking agents such as serum albumin and skim milk
  • Familiarity with buffer solutions and their role in maintaining pH and salt concentration
  • Basic principles of protein binding affinity
  • Research the effects of different blocking agents on antibody specificity
  • Learn about optimizing pH and salt concentration in immunoassays
  • Investigate the role of Tween as a blocking agent in various applications
  • Explore methods to measure antibody affinity in hybridization experiments
Researchers and laboratory technicians involved in immunological studies, particularly those optimizing antibody hybridization protocols and blocking strategies.
Monique
Staff Emeritus
I was wondering how the blocking of a sample works with serum before hybridizing it with an antibody.
I mean, you want to block everything aspecific so that the antibody doesn't bind everthing, but with that it blocks things that the antibody is supposed to bind right?
Or is it all about affinity, the antibody should have enough affinity to bind no matter that it is blocked..
And exactly what is the blocking agent in serum? Albumin? And why does it block?
I'm braindead after waking up at 6 and coming home at 7, eating and after that studying and then going to sleep around midnight..
Biology news on Phys.org
The blocking solution is made with a blocking agents which is could either be serum albumin, skim milk or tween. The blocking agent will cover the protein or surface with a slight coat and block unspecific binding but it will not influence the specific binding.
I think the pH, salt concentration and concentration of blocking agent will influence the stringency of the binding. pH and salt concentration probably need to be stable because buffers are always used.
10K
