Calculating Sums of Infinite Series for Nille
The discussion revolves around methods for calculating the sums of infinite series, specifically focusing on two series presented by a participant named Nille. The series in question are \(\sum_{n=0}^\infty\left(\frac{n+5}{5n+1}\right)^n\) and \(\sum_{n=0}^\infty\frac{\cos n\pi}{1+n^2}\). Participants explore convergence and potential summation techniques.
  • Nille inquires about methods to find the sum of the infinite series, noting that the first series converges and appears to sum to 2.
  • One participant states that there is no general method for determining the sum of an infinite series.
  • Another participant suggests finding the sum to \(n\) terms and then taking the limit as \(n\) approaches infinity.
  • A different participant claims the sum of the first series is approximately 2.5746952396343726343.
  • For the second series, a participant provides a specific expression involving hyperbolic functions, asserting it converges to \(\frac{1}{2}\left(1+\pi{\rm csch}(\pi)\right)\).
  • Nille expresses confusion about how participants reached their conclusions regarding the sums.
  • Nille mentions that the second series does not involve hyperbolic trigonometric functions and references Taylor series.
  • A participant named Laura requests clarification on the use of Taylor series in relation to the second series, questioning the conversion process.
Participants do not appear to reach a consensus on a specific method for summing the series, and multiple competing views regarding the summation techniques and results are present.
Some participants express uncertainty about the methods used to arrive at the proposed sums, and there is a lack of clarity on the application of Taylor series to the second series.
nille40
Hi all!
I was wondering which method one should use to find the actual sum of an infinite series. I know how to find the sum of a geometric series (if it converges), but how could I find the sum for, for instance
[tex] \sum_{n=0}^\infty\left(\frac{n+5}{5n+1}\right)^n[/tex]
I know that it converges, and the sum appears to be 2. But how can I calculate this?
Or how about
[tex] \sum_{n=0}^\infty\frac{\cos n\pi}{1+n^2}[/tex]
Thanks in advance,
Nille
There is no general method for determining the sum of an infinite series.
What if we try to find the sum to n terms and then taking lim [tex]n\rightarrow\infty[/tex]
The answer to the first one is 2.5746952396343726343 Hope that will help
The second one is a defined convergent series:
[tex]\sum_{n=0}^\infty\frac{\cos n\pi}{1+n^2}=\frac12\left(1+\pi{\rm csch}(\pi)\right)[/tex]
where csch(z) gives the hyperbolic cosecant of z, or in other words: csch(z)=1/sinh(z).
How You guys reach this conclusions I have read a little about convergence and divergence but don't know how you summed up the series
This one does not involve hyperbolic trig functions.
Taylor series.
laura: would you mind explaining further? Since the sum, as written, is clearly not a Taylor series, do you mean that it can be converted to one and then summed? If so, how? It's certainly not obvious to me!
