JonnyW
- 4
If a telescope is 2 time bigger in diameter then you can see object 4 times fainter, but does that mean that object appear 4 times brighter?
The discussion centers on the relationship between telescope diameter and the perceived brightness of celestial objects, exploring whether a larger diameter results in objects appearing brighter. The conversation includes theoretical considerations, calculations related to magnitude, and the effects of human vision on brightness perception.
Participants do not reach a consensus; multiple competing views remain regarding the relationship between telescope diameter, light gathering, and perceived brightness.
Limitations include the dependence on definitions of brightness, the complexity of the magnitude system, and the variability in human vision capabilities, which are not fully resolved in the discussion.
Well, I am not one of the "smart guys", but I have been using and making telescopes for many years and can add just a bit to the original question on "telescopes".Originally posted by StephenPrivitera
I think you can do a rough calculation of limiting magnitude using the fact that your eye has a 1cm aperture and can see to the 6th mag.
[tex]m_{lim} - m_{eye}= -2.5log \frac {f_{tel}} {f_{eye}} = -2.5log \frac {A_{eye}} {A_{tel}}[/tex]
[tex]=-2.5logR^2_{eye}/R^2_{tel}[/tex]
Use 6 for m_eye and 1cm for R_eye
Yes, I believe the object appears four times brighter. That is, the object actually is four times brighter. But your eye responds to light logarithmically so it will seem about log4 times as "bright". It depends on how you define "bright".
I think that's how it works. One of the smart guys will correct me if it's not.
I'm not sure it is. If one brings in 4x as much light, things should appear 4x brighter. That does only correspond to a magnitude difference of 1.6 though(if I'm using the scale correctly).Originally posted by Artman
Not exactly. The one number is a magnitude measurement.
That's a huge fact.Originally posted by russ_watters
This is also complicated by the fact that our vision doesn't have linear brightness sensitivity.
