Lock Folder: Protect Data Without Password (Windows)
  • Thread starter Thread starter Mattius_
The discussion revolves around methods to protect data in Windows folders without using a password. Participants explore various techniques, including folder encryption, NTFS permissions, and alternative approaches like compression and password protection of zip files. The conversation covers both theoretical and practical aspects of data protection on Windows operating systems.
  • Some participants inquire about the possibility of password-protecting a Windows folder and suggest that folder encryption is a viable alternative.
  • It is noted that having administrator rights allows users to control access to folders, and that NTFS format is necessary for certain security features.
  • Participants discuss the limitations of Windows in comparison to Linux regarding user permissions and folder access management.
  • There are suggestions to use the security tab in folder properties to restrict access to specific user accounts, although concerns about system accounts and administrator rights are raised.
  • Some participants propose compressing folders into zip files and password-protecting them as another method of securing data.
  • A question is raised about the maximum size and directory levels for encrypted zip files, indicating a need for practical guidance on maintaining organizational structure while encrypting data.
Participants express varying opinions on the best methods for protecting folder data, with no clear consensus on a single approach. The discussion includes both agreement on the necessity of NTFS for certain features and disagreement on the feasibility of removing administrator rights.
Limitations include the dependence on specific Windows versions and file systems, as well as the unresolved nature of the maximum size and directory levels for encrypted zip files.
Mattius_
Can you put a password on a windows folder? If not, what is the next best thing?
Computer science news on Phys.org
To do this, you will need at least Windows XP, or Server 2003 (and maybe, maybe NT 4.0, but nobody uses that anyway). I haven't got any experience with those, unfortunately.
The "next best thing" would be folder encryption. There are quite some nice encryption programs which have a function to encrypt and decrypt complete folders.
If you have adminitrator rights you can edit what users have access to certain folders. That is also why, if you use a user account, you do not have access to other users home directory.
I am sure it would be way easier on a linux machine...
You will of course need the format on your harddrive to be NTFS.
Any Windows OS that uses NTFS can do what u require..
there's a section in windows help that has a step by step that i want to try out later.
As it was mentioned here, if you have NTFS, which you probably do (unless you have Win 9x, Me, or an XP, 2000, 2003 installation on top of an old one) then you can create a folder, right-click on it, select properties, on the security tab you can make sure that yours is the only user account that has read/write access. A couple of things to keep in mind is that there are system accounts that the Operating System or services use which generally you wouldn't have to worry about unless you are using your folder for more than just storing data. Another thing is that i don't believe you can remove the Administrator's rights over any folder you create, that's why it helps if you're the administrator (also because you might need Admin rights to modify the security information).
Encription sounds more like what you need, of course you'd need to encript/decript it everytime you want to use the folder. Maybe a better alternative is to simply compress it with a .zip program and password protect it.
You can remove the Administrator... As long as you account is nested in the Admin group...
The problem is that u can if u are the admin take ownership of the folder and then add the admin account back into the ACL's
True, because Linux essentially is multi-user. Of course, it mainly depends on the filesystem used.
What is the maximum size and number of directory levels for an encrypted zip file? I would like to encrypt the entire directory structure (~8 GB) on my portable USB hard drive without losing the organizational structure.
  • · Replies 84 ·
  • · Replies 28 ·
  • · Replies 24 ·
11K
