| Thread Closed |
Electric field & Parallel plate Capacitor |
Share Thread | Thread Tools |
| Jan8-06, 09:57 AM | #1 |
Question When a nerve impulse propagates along a nerve cell, the electric field within the cell membrane changes from 7.0 x 10^5 N/C (pointing in one direction) to 3.0 x 10^5 N/C (pointing in the other direction). By approximating the cell membrane as a parallel-plate capicator, find the magnitude of the change in charge density on the walls of the membrane
| Jan9-06, 03:08 PM | #2 |
Has anyone ANY ideas?
| Jan9-06, 04:07 PM | #3 |
Mentor
What are the typical dimensions of such a cell? What is the typical thickness of the membrane? Do you know the formula for the capacitance of a parallel plate capacitor in terms of C, epsilon, Area and separation Distance? (ignoring fringe capacitance effects)
| Jan10-06, 04:40 AM | #4 |
Oh sorry, the thickness is 0.12 micrometres
and the parallel plate capacitor has a surface charge density of 5.9×10^-6 C/m2 |
| Jan10-06, 10:02 AM | #5 |
Mentor
| Jan10-06, 03:13 PM | #6 |
No I don't. What is it?
| Jan10-06, 03:52 PM | #7 |
Mentor
epsilon = permittivity A = area of one parallel plate d = separation of the parallel plates. So you can take the typical dimensions for the cell membrane configuration, and calculate the capacitance (you'll need to approximate the epsilon of the cell membrane -- I have no idea what it is), and that will give you the equivalent capacitance. Given the change in electric field, you can calculate what charge change it takes to make that happen. That and the area will give you the charge densities.... |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electric field & Parallel plate Capacitor
| Distance-Varying Electric Field and Voltage of Parallel Plate Capacitors | Introductory Physics Homework | 4 | ||
| magnetic field for parallel plate capacitor | Introductory Physics Homework | 6 | ||
| A proton is released from rest at the positive plate of a parallel-plate capacitor. | Introductory Physics Homework | 16 | ||
| field momentum inside a parallel plate capacitor | Classical Physics | 4 | ||
| Electrical Field of a Parallel Plate Capacitor | Introductory Physics Homework | 3 | ||
