Thread Closed
Calculating moment of inertia of a system of balls
Share Thread Thread Tools
Jan9-06, 07:12 AM   #1
I have a bit hard time calculating moment of inertia of a a system of balls. The system is defined as follows: 3 balls that are the same are connected with thin rods soo that the center of each ball is in the corners of a equilateral triangle with length of side to be 0.3 m. Radius of each ball is 0,08 m and mass of each ball is 1,2 kg. Now the fun part: Calculate moment of inertia of the system if the axis of rotation goes trught the center of mass of the equilateral triangle. I of ball is 2/5*m*r^2.
I am puzzled. I know that the center of mass for a equilateral triangle is in 2/3 of its height. Soo each ball is exacly 1/3*Sqrt(3)*a -> 1/3*Sqrt(3)*0,3m away from the axis of rotation. I would simply say that the moment of inertia I = Sigma(m*r^2). I of each ball is I of b = m*(1/3*Sqrt(3)*a)^2 = 1.2 kg * 1/9 * 3 * 0.09 m^2. And then the moment of inertia of the system is simply I of system = 3 times I of ball. I am missing something. Since the radious is also given. I would apprichiate greately if somebody would explain the reasoning behind this problem and also if possible the path to solution.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan9-06, 07:34 AM   #2
Recognitions:
Homework Helper Homework Help
Go through the parallel axis theorem of M.I.
The ball is not a point mass.
Jan9-06, 07:46 AM   #3
Ah...
The Moment of inertia of the ball is I = 2/5*mass*radius^2 + mass*distance from the axis of the system^2. And the moment of inertia of the system if 3 times of that of single ball?
Jan9-06, 07:50 AM   #4
Recognitions:
looks good !
Jan9-06, 09:51 AM   #5
Ok, Thanks!
Thread Closed
Thread Tools
Similar Threads for: Calculating moment of inertia of a system of balls
Thread Forum Replies
Calculating moment of inertia Introductory Physics Homework 4
Calculating Moment of Inertia General Physics 5
Calculating Moment Of Inertia Introductory Physics Homework 3
Calculating the moment of inertia General Physics 3
Calculating moment of inertia Introductory Physics Homework 2
