Hook's Law: Mass & Streaching Value Calculation
The discussion revolves around applying Hook's Law in the context of a mass-spring system. The original poster is tasked with calculating the mass and the stretch of a spring when a mass is attached, given the spring constant and frequency of vibration.
  • Participants discuss the appropriate formulas to use, with some suggesting Hook's Law while others question the relevance of certain equations. There is a focus on the relationship between frequency, mass, and spring constant, and how to manipulate these equations to find the desired values.
Participants are actively engaging with the problem, exploring different interpretations of the equations involved. Some guidance has been offered regarding the algebraic manipulation needed to isolate the mass, but there is no clear consensus on the correct approach or the relevance of certain variables.
There is uncertainty regarding the application of gravitational acceleration in the context of the problem, as well as the correct interpretation of frequency and period in relation to the equations being discussed.
StaticShock
What formula should I use for this question? I'm thinking hook's law, but It doesn't seem to fit.
A mass is attached to a spring that has a constant of 100 N/m. The mass vibrates with a frequency of 2 Hz.
I have to find the value of the mass and how far it streaches. I know I can use hook's law for the streaching part, but I am unsure of how to carry out this problem.
[tex]T = \frac {1}{f} = 2 \pi \sqrt {\frac {m}{k}}[/tex]
Are you sure that's the right one? I mean, it looks as if its finding period not frequency. So wouldn't it be F=1/t= 1/2 pi Sqroot k over m?
that's just the general equation. it's up to you to do the algebra that will give you the value that you want.
well based on some information I found, the square root of the mass over K is equal to the equation of L over g. If all things are reletive then, I should be able to switch it as i would when finding frequency.
However, the second question may not have anything to do with hooke's law at all. It may just be F= 1 over 2pi Sqrt g over L
But I am unsure if g is to be used based on Earth's speed of gravity or if I am on the right track at all.
why do you do this? the equation i gave you has frequency, mass, and the spring constant. you know two of these, so just solve for the mass.
  • · Replies 35 ·
