Trouble with Deriving Moment of Inertia for a Spherical Ball
The moment of inertia for a spherical ball of mass m and radius r about the axis z through its center of gravity is derived as I_G = (2/5)mr^2. The user initially attempted to derive this using the integral I_G = ∫_m r^2 dm, substituting dm = ρ dV, but arrived at an incorrect result of (3/5)mr^2. The discussion highlights the necessity of integrating over the square of the distance from the axis of rotation, specifically r^2 sin²(θ), and emphasizes the importance of considering the perpendicular distance in the calculations.
  • Understanding of moment of inertia concepts
  • Familiarity with integral calculus
  • Knowledge of spherical coordinates
  • Basic physics principles related to rotational motion
  • Study the derivation of moment of inertia for different shapes, including cylinders and disks
  • Learn about the application of triple integrals in calculating mass distributions
  • Explore the use of polar coordinates in physics problems
  • Review the principles of rotational dynamics and their mathematical representations
Students of physics, mechanical engineers, and anyone interested in understanding rotational motion and moment of inertia calculations.
Benny
I am having trouble with the following question.
Q. Derive the expression for the moment of inertia of a spherical ball of mass m and radius r about the axis z through its centre of gravity.
Ans: [itex]I_G = \frac{2}{5}mr^2[/itex].
I did the following.
[tex]I_G = \int\limits_m^{} {r^2 } dm[/tex]
[tex]dm = \rho dV[/tex] where rho is the constant density.
[tex] V = \frac{4}{3}\pi r^3 \Rightarrow dV = 4\pi r^2 dr[/tex]
[tex] I_G = 4\pi \rho \int\limits_0^r {r^4 dr} = \frac{{4\pi r^5 \rho }}{5} = \frac{3}{5}\left( {\frac{4}{3}\pi r^3 \rho } \right)r^2 = \frac{3}{5}mr^2 \ne \frac{2}{5}mr^2 [/tex]
I can get the answer using a triple integral but the question seems to only require a single integral. At the moment I can't see where I've gone wrong. Can someone help me out? Thanks.
To calculate the moment of inertia you need to integrate over the square of the distance from the axis of rotation which is [itex]r^2 \sin^2 \theta[/itex] and not just [itex]r^2[/itex]. This also requires you to integrate over the polar angle.
Oh ok. I just looked up the definition on mathworld and it appears to say that a perpendicular distance needs to be considered. Hopefully these will become more easy to do as I get more practice. Thanks for the help.
