Sound intensity and ocean microphone
The forum discussion centers on calculating the distance a porpoise can be from an ocean microphone while still being heard, given a sound intensity threshold of 10.6 dB and a sound power output of 0.0502 W. The correct intensity calculation yields 1.148E-11 W/m², leading to a distance of 1.87E+4 meters. The initial miscalculation arose from an incorrect intensity value, which was ten times larger than the correct figure. The final resolution confirms the accurate distance using the formula r = √(P/(4πI)).
  • Understanding of sound intensity and decibel calculations
  • Familiarity with the formula for sound propagation: I = P/(4πr²)
  • Basic knowledge of logarithmic functions and their applications in physics
  • Concept of sound power and its relationship to distance in a medium
  • Study the principles of sound intensity and its measurement in different mediums
  • Learn about the effects of distance on sound propagation in water
  • Explore advanced applications of logarithmic calculations in acoustics
  • Investigate the impact of environmental factors on sound transmission underwater
Acoustics researchers, marine biologists, and anyone involved in underwater sound monitoring and analysis will benefit from this discussion.
Corky
The problem states:
A microphone in the ocean is sensitive to sounds emitted by popoises. To produce a usable signal , sound waves striking the microphone must have an intesity of 10.6 dB. If porpoises emit sound waves with a power of 0.0502 W, how far can a porpoise be from the microphone and still be heard? Disregard ansorbtion of sound waves by water.
I tried putting 10.6 decibels in the equation dB=10Log(I/Io)
and I solved for intensity to be 1.148E-10W/m^2
I then used that number in the I = P/4pi r^2 formula.
Solving for r I got 5.89E+3m.
But the right answer it the book is 1.87E+4
Can anyone tell me where I went wrong??
10log(I/(10^-12)) = 10.6
log(I/(10^-12)) = 1.06
I/(10^-12) = 10^1.06
I = 1.148e-11
I = P/(4pi r^2)
r^2 = P/(4pi I)
r^2 = 0.0502/(4pi 1.148e-11)
r^2 = 3.4797e8
r = 18654m
r = 1.87e4
I think the error was in what you thought the value for I was. Your I is 10x as big as mine.
Nice thanks
