Proving that a certian subset of L^1([0,1]) is closed
  • Thread starter Thread starter benorin
    Closed
The discussion focuses on proving that the set M, defined as all functions f in L^1([0,1]) such that the integral of f over the interval equals 1, is a closed convex subset of L^1([0,1]). The convexity of M is established through the linear functional Λ defined by Λf = ∫_0^1 f(t) dt. The challenge lies in demonstrating that M is closed, which is addressed by showing that if a sequence of functions {f_k} in M converges to a function f, then Λf must equal 1, confirming that f is also in M. The topology of the space plays a crucial role in this proof.
  • Understanding of L^1 spaces and Lebesgue measure
  • Knowledge of linear functionals and their properties
  • Familiarity with convex sets and their definitions
  • Basic concepts of functional analysis and topology
  • Study the properties of L^1 spaces and their applications in functional analysis
  • Learn about the continuity of linear functionals in normed spaces
  • Explore the concept of closed sets in topological spaces
  • Investigate the implications of convexity in functional analysis
Mathematicians, particularly those specializing in functional analysis, graduate students studying measure theory, and researchers interested in properties of L^1 spaces.
benorin
Insights Author
The problem: Let M be the set of all [tex]f\in L^1 \left( \left[ 0,1\right] \right)[/tex] relative to the Lebesgue measure, such that
[tex]\int_{t=0}^{1}f(t)dt = 1[/tex].
Show that M is a closed convex subset of [tex]L^1 \left( \left[ 0,1\right] \right)[/tex] which contains infinitely many elements of minimal norm.
What I've got: Define the linear functional [tex]\Lambda f = \int_{t=0}^{1}f(t)dt[/tex]
Convexity is easy, for any f,g in M and s in (0,1) put [tex]h_s(t)=sf(t)+(1-s)h(t)[/tex] so that
[tex]\Lambda h_s = \Lambda \left( sf+(1-s)h\right) = s\Lambda f + (1-s)\Lambda g = s + (1-s) = 1\Rightarrow \int_{t=0}^{1}h_s(t)dt = 1\Rightarrow h_s\in M[/tex]
by which it is understood that M is convex.
That M is closed is my first trouble. Let [tex]\left\{ f_k\right\} \rightarrow f[/tex] be a sequence of vectors such that [tex]f_k\in M,\forall k\in\mathbb{N}[/tex]. Then we know that
[tex]\forall \epsilon >0, \exists N\in\mathbb{N}\mbox{ such that }k\geq N\Rightarrow \| f_k - f\| = \Lambda \left( |f_k - f|\right) < \epsilon[/tex]
How do I prove that [tex]f\in M[/tex] ? Can I show that [tex]\Lambda[/tex] is a bounded linear map (actually functional) from [tex]L^1 \left( \left[ 0,1\right] \right)[/tex] into [tex]\mathbb{C}[/tex]?
Think I got the closed part:
[tex]|1 - \Lambda f |=|\Lambda f_k - \Lambda f |=|\Lambda \left( f_k - f\right) |\leq \Lambda \left( |f_k - f|\right) < \epsilon\Rightarrow 1-\epsilon < \Lambda f < 1+ \epsilon[/tex]
anbd since [tex]\epsilon[/tex] is arbitrary, [tex]\Lambda f =1\Rightarrow f\in M,[/tex] right?
I think you're making it more complicated than it is. I mean, what is the topology on the space? Surely it is then trivial that the inverse image of a the point 1 under the (continuous, from the topology you put on the space!) functional f--> integral(f) is closed.
  • · Replies 105 ·
13K
