Electric Force Calculation Using Coulomb's Law | Problem 3, 9
  • Thread starter Thread starter mustang
    Law
The discussion revolves around calculating electric forces using Coulomb's Law, specifically focusing on two problems involving charged spheres and point charges. The first problem involves two identical conductive spheres with different charges, while the second problem deals with three point charges positioned along the x-axis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore how to apply Coulomb's Law to find electric forces, questioning the method of averaging charges and the implications of charge signs on force direction. There are discussions on calculating electric fields and forces as vectors, and the necessity of considering direction in the calculations.
Participants are actively engaging with the problems, offering various approaches and clarifying concepts related to electric fields and forces. Some guidance has been provided on using vector forms and superposition principles, but no consensus has been reached on specific calculations or outcomes.
There are indications of confusion regarding the application of Coulomb's Law and the interpretation of charge signs. Participants also express uncertainty about the expected magnitudes of forces in electrostatics.
mustang
Problem 3.
Two identical conduction spheres are placed with their centers 0.34m apart. One is given a charge of +13*10^-9 C amd the other is given a charge of -14*10^-9 C. The spheres are connected by a conductiong wire.
After equilbrium has occurred, find the electric force between the teo spheres. Answer in N.
Note: Would you add up the charges divide by two and the put it in Colulomb's law were it is the charged squared? From there find the electric force?
Problem 9.
Three point charges , q_1=+6.6 uC, q_2=+2.4uC, and q_3=-2.4uC, lie along the x-axis at x=ocm, x-2.4 cm, and x=5.3 cm, respectively.
a. What is the force exerted on q_1 by the two charges? (To right is positive) Use 8.99*10^9 N*m^2/C^2. Answer in N.
Note: How would put these values in Coulomb's law?
yes for first part
Find the field at the point q1 due to q2 & q3 sayit is E
Then force will be q1E
re #9:
remember that E is a vector. THe "+" and "-" values that you get with Coulomb's equation do not tell you the direction is to the right or to the left. Draw a picture for E from q2 and from q3. IF they point in the same direction then the two E's add up. IF they point in different directions, then you subtract values, and the direction of the net E is the same as the larger E.
From Couloumbs law u can calculate the direction
the Vector form for Coulombs law is
[tex] \vec F = \frac{kq_1q_2}{\vec r^3} \vec r[/tex]
The thing is u have to put the sign of q1&q2 along with magnitude
regarding question 9
To find magnitiude of the force of q_1 don't I use Coulomb's law twice. Once with the second charge to be 2.4uC and another time with second charge -2.7uC, with both charges being multiplyied with 6.6uC.
Then I will get two amounts whih i would multiply with what?
I was just giving the formula in vector form
U got it right u will have to do with charges
Got the force due to both charges say F1,F2
Apply the superposition Net force= F1+F2
Note you have to add vectors force is vector
Is the answer -190.1888733N.
U never get such an enormous force generally in Coulombs law or in Electrostatics
I just noticed there is a simple way of doing the problem
The given set of charges forms a dipole
U can use the equation of Field in axial line for a dipole
9K
10K
