Understanding the Impact of Pendulum String Length on Oscillation Time
  • Thread starter Thread starter warriorofrovac
    Gravity Pendulum
The length of the string attached to a pendulum directly affects the oscillation time, with shorter strings resulting in quicker oscillations. This relationship can be quantitatively described using the formula for the period of a simple pendulum, T = 2π√(L/g), where L is the string length and g is the acceleration due to gravity. Additionally, the discussion highlights the use of linear differential equations to model pendulum motion, as well as the complexities introduced by non-linear differential equations. Experimental data collected from strings ranging from 30 to 100 cm supports these theoretical findings, showing a clear inverse relationship between string length and oscillation time.
  • Understanding of basic physics concepts, particularly pendulum motion
  • Familiarity with the formula for the period of a pendulum (T = 2π√(L/g))
  • Knowledge of linear and non-linear differential equations
  • Ability to conduct and analyze experiments involving oscillation timing
  • Research the derivation of the pendulum period formula using linear differential equations
  • Explore the properties of non-linear differential equations in modeling pendulum motion
  • Learn about the effects of damping on pendulum oscillations
  • Investigate experimental methods for measuring oscillation periods with varying string lengths
Students studying physics, educators teaching mechanics, and anyone interested in the dynamics of oscillatory motion.
warriorofrovac
why does the length of string attached to a pendulum affect the time it takes for one oscillation
This is a homework problem? Then show us what you have done on it and what you DO know about the situation. One reason for that (in addition to the fact that the more you do the better) is that it helps us know what kind of help you need and what would make sense to you. I know several ways of answering this question. One involves using a simple formula for the period of a pendulum that you may or may not know. Another involves solving a linear differential equation, that approximates the motion of pendulum, to derive that formula. Still a third involves using properties of a very difficult (and not solvable exactly) non-linear differential equation that exactly models the pendulum. I have no way of knowing if any of those are appropriate here.
a bob attachted to a piece of string
The length of the strings range from 30 to 100cm in 10cm intervals
the bob is pulled back roughly 6cm and let go
I time how long it takes for the bob to complete 10 oscillations and plot the results for all the lengths of the string, i get a graph which curves.
what i want to know is..why is the time less for one oscillation when the length of the string is shorter, against the time for when the length of the string is longer?
  • · Replies 21 ·
  • · Replies 32 ·
