Calculating Work Needed to Stop a 1000kg Car at 100km/h
  • Thread starter Thread starter dzem68
    Car Work
The discussion focuses on calculating the work required to stop a 1000kg car traveling at 100km/h. The conversion of speed from kilometers per hour to meters per second is essential, resulting in 27.78 m/s. The kinetic energy formula, \( W = \frac{1}{2}mv^2 \), is applied to determine the work needed, yielding a result of 385,800 Joules. This calculation demonstrates that the work required to stop the car is equivalent to its initial kinetic energy.
  • Understanding of kinetic energy and the formula \( W = \frac{1}{2}mv^2 \)
  • Ability to convert units from kilometers per hour to meters per second
  • Familiarity with the concepts of work and energy in physics
  • Basic algebra skills for solving equations
  • Study the principles of energy conservation in physics
  • Learn more about the relationship between work, energy, and force
  • Explore real-world applications of kinetic energy calculations
  • Investigate the effects of friction and other forces on stopping distances
Students studying physics, automotive engineers, and anyone interested in the mechanics of motion and energy transfer.
dzem68
This should be easy...the problem asks for the amount of work needed to stop a 1000kg car traveling @ 100km/h.
I am having a hard time do to the fact acceleration,distance nor time is given.
here is how I think i need to approach this:
convert 1000km/h to m/sec
find acceleration
use Work=Mas*acceleration*Distance to find work
Here are the variables i know:
Mas=100kg
Vf = 0
V0 = 27.78 m/s
how can i find acceleration if no distance or time is given? I would think i need to find acceleration to calculate work needed to stop.
any hints?:smile:
dz
convert speed to m/s:
100km/h * 1000m/km * h/3600s = 27.7777m/s
you have to remember the standard formula for all of these types of problems is energy in = energy out. expanded, it looks like this:
Wo + Ko + Po = Wf + Kf + Pf
W is work, K is kinetic energy, P is potential energy. For this equation, there is no work put in, no initial potential energy, no final potential energy, no final kinetic energy. With all the 0 terms removed, it looks like this:
Ko = Wf
solfing for equation:
(1/2)mv^2 = W
(1/2)(1000)(27.777^2) = W
W = 385800J
W = 3.858 x 10^5 J
In order to stop any object, you need to reduce its velocity to 0. That means you need to reduce its kinetic energy to 0. Work is energy so: calculate the kinetic energy. That's the work you need to do to stop the object.
