Questions on Agilent DC Power Supply Schematic with CC
  • Thread starter Thread starter waht
    Schematic
The discussion focuses on the Agilent DC power supply schematic, specifically addressing the roles of components such as diodes CR10 and CR11, resistors R2 and R34, and jumpers JP1 and JP2. The diodes are confirmed to prevent excessive voltage at the op-amp's input, while the current through R2 is measured using a bridge circuit involving R27, R34, R18, and R17. The connection between V+ and +S is implied but not explicitly shown in the schematic, indicating a need for further investigation into the circuit's design.
  • Understanding of operational amplifier circuits
  • Familiarity with bridge circuit configurations
  • Knowledge of diode functions in electronic circuits
  • Basic comprehension of schematic symbols and notations
  • Research the function of operational amplifiers in current sensing applications
  • Study the design and analysis of bridge circuits
  • Examine the role of diodes in protecting sensitive components
  • Investigate the implications of high impedance measurements in power supply circuits
Electronics engineers, circuit designers, and students studying power supply design and operational amplifier applications will benefit from this discussion.
waht
This is an Agilent DC power supply schematic with CC. I've been going over it and got a few questions.
What is the purpose of 2 diodes CR10 CR11 in the current error amplifier and how is the current amplifier suppose to measure voltage across R2? Why do we need R34 ?
Also what does JP1 and JP2 do?
I would say that the diodes are to prevent too much voltage from developing across the input of the op-amp. The current through R2 (voltage across it) is sensed by the bridge circuit formed by R27 and R34 (one side) and R18 and R17 (other side). Somehow, through J1 (3) V+ there must be a connection back to +S. I don't see it on the schematic though. But it must be present in order for U4B to develop an input voltage. It may not be a direct connection, but there must be something that relates them.
Well, the V+ V- and I+ I- are high impedance digital voltmeters. One to measure voltage across the output and the other was suppose to display current by measuring voltage across R2.
The weird aspect of this schematic is the positive output terminal is basically a ground with respect to the bias supply S+ .
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 32 ·
