Understanding Uniform Circular Motion: The Role of Perpendicular Acceleration
  • Thread starter Thread starter KD
    Concept
The discussion revolves around understanding uniform circular motion, specifically focusing on the implications of forces and acceleration being perpendicular to velocity. The original poster seeks clarification on the nature of perpendicular forces and their significance in describing the motion of a body with constant acceleration that is always perpendicular to its velocity.
  • Participants explore the concept of perpendicular forces and their independence, questioning why this relationship is significant. They discuss the implications of constant acceleration being perpendicular to velocity, leading to circular motion, and consider the absence of tangential acceleration in this scenario.
Some participants have provided insights into the nature of uniform circular motion and the role of centripetal acceleration. There is an ongoing exploration of the definitions and implications of tangential versus centripetal acceleration, with questions about the importance of the perpendicular relationship remaining open for further discussion.
The original poster is working within the constraints of a homework assignment, seeking hints rather than complete solutions, which shapes the nature of the discussion.
KD
What does it really mean when forces are perpendicular to each other? Is it that they are independent of each other?
And if so, why is that so special?
I ask these questions to answer this homework question: Describe the path of a moving body whose acceleration is constant in magnitude at all times and is perpendicular to the velocity.
It is in the topic of tangential and centripetal acceleration. Please give some helpful hints. Thanks.
Velocity is a vector unit. If the acceleration acts perpendicular to the velocity, the moving body should be moving with circular motion.
We like to be able to break vectors down into components that are perpendicular to each other so that we can manipulate them, i.e. add or subtract other vectors and conduct other calculations concerning the problem. For instance, to find the centripetal force, we need to know the direction to the radius of the curve, or normal direction to correctly do calculations. This let's the other component, tangential, be along the path of motion.
In your question, the body never speeds up or slows down. So you have to know that there is no acceleration tangentially. All the acceleration is in the normal direction. What path would this create?
Uniform circular motion occurs when an acceleration of constant magnitude is perpendicular to tangential velocity.
Okay, so to just think through this, tangential velocity would be with changing speeds, in a straight line? And centripetal - center seeking- always circular.
Tangential -speed Centripetal - direction.
Constant in magnitude so there is no change in speed so there is no tangential acceleration. So you can only assume that it is going with the other component of acceleration - centripetal. So it has to go in a circular path. With that being said, why is "perpendicular to the velocity" even essential to the question?
Thanks for your help!
  • · Replies 31 ·
