Volume vs temp vs pressure question
  • Thread starter Thread starter Rusho
    Pressure Volume
The discussion revolves around the behavior of gases in a sealed container, specifically examining the relationships between volume, temperature, and pressure. Participants explore whether increasing temperature or pressure affects the volume of gas, while also considering concepts such as density and the ideal gas law.
  • Participants discuss the implications of increasing temperature and pressure on the volume of gas in a sealed can, questioning the distinction between volume and quantity of gas. Some explore the ideal gas law and its relevance to the scenario, while others raise questions about the nature of pressure and density.
The discussion is ongoing, with participants providing insights into the ideal gas law and clarifying concepts related to pressure and volume. There is a mix of interpretations being explored, and some participants have expressed understanding of the concepts discussed.
Participants are working within the constraints of a sealed container, which limits the ability of gas to escape or enter. The discussion also touches on the complexities of gas behavior under varying conditions, including the introduction of additional variables like the coefficient of expansion.
Rusho
So here is the question:
I have a gas contained in a volume(like a sealed can). If I increase the temperature does the volume stay the same?
If I increase the pressure, does the volume stay the same?
It seems like it would, but I think volume is confused with "quantity", which I can see changing in all of the above circumstances.
Thx for any help
If you have a sealed can(none of the gas can escape) you will not see an increase in volume. I think you acn see why. If you approximate this general gas as an Ideal gas, obeying the equation of state PV=nRT, you see that if you increase the temperature in a constant volume process that the pressure must also increase (by looking at the equation PV=nRT, where V,n,R all constant)
Cheers,
Norm
How is the quantity changing if you've got a sealed can?
hmmm.
Well if a person can pack more pressure in, then more molecules are entering, so more "quantity", but the volume is the same. So its more dense?
I think you are confused with what is meant by pressure. Pressure is force per unit area (F/A), so increasing the pressure does not mean increasing the number of molecules (n). It means that the force imparted on the surface has increased. You can think of this is each molecule having more momentum so when it bounces off the container, its change in momentum is greater thus making a larger force (per Newton's second law). Does that make more sense (or any at all)?
good luck,
Norm
Yes, I understand.
Thx!
The "ideal gas law" is PV= NRT.
T is the temperature (in degrees Kelvin), P is the pressure, V is volume, N the number of molecules (or mols depending on how R is taken) and R is "Boltzmann's constant". If you take a "sealed" can (so that no molecules can get in or out) then N stays the same. You can increase pressure, P, by increasing T (heat the can) while V stays constant or by decreasing V (imagine one end of the can as a plunger that can be pushed down into the can) while T remains the same (you will have to push the plunger down slowly, allowing any increase in temperature due to the energy exerted to "bleed off" to the environment around the can.
I have an, only peripherally, related question.
Given a container with a gas, assuming a constant internal/external pressure differential, with a hole of a particular diameter/area, what is formula to compute the rate at which the gas exits the hole.
Assume we're talking ideal gas or air and anything else that I haven't given, but are needed.
(P1T1)/V1=(P2T2)/V2
Nautica
temp vs. Pressure
Hi All,
I like some of the answers and the direction that this discussion is headed, but let's add one more varible to the equation, that is needed for liquids in sealed containers:
" Coefficient of Expansion for Liquids and Gases"
Now, with this in mind let's think another variable related to expansion of liquids and gases in a liquid state within a sealed container ,,,, say an aerosol can filled to the top;
Electrons + heat > coefficient of Expansion > Possible Hydraulic pressure or vapor Pressure
You are 3 years too late. The ship has left the harbor.
You might want to pay attention to the DATE of the thread and the last post.
Zz.
  • · Replies 67 ·
