Solving the Mystery of Heat on Earth: Average Energy Needed to Warm the Planet
  • Thread starter Thread starter Blissfulpain
    Earth Heat
The discussion centers on calculating the average energy required to warm the Earth by 1 degree Celsius by averaging the specific heat capacities of various materials. Participants explore whether it is feasible to combine the specific heat capacities of liquid water and gaseous oxygen when mixed, and whether salination affects water's capacity. The complexities of phase changes and chemical reactions at different temperatures are acknowledged, emphasizing the challenges in deriving a sensible average for the entire planet.
  • Understanding of specific heat capacity
  • Basic knowledge of thermodynamics
  • Familiarity with phase changes in materials
  • Concept of thermal equilibrium
  • Research the specific heat capacities of various materials, including water and salt solutions
  • Study the principles of thermodynamics related to energy transfer
  • Explore the effects of phase changes on thermal properties
  • Investigate the concept of thermal equilibrium in geological contexts
Students and professionals in environmental science, physics, and chemistry, particularly those interested in thermodynamics and climate science.
Blissfulpain
[SOLVED] Heat on Earth
just curious... would it be reasonable to add up all the materials in Earth and then average their specific heat capacities to determine an average amount of energy needed to warm the Earth by 1 degree?
i suppose it could be broken down to if you have 1 mol of liquid water and 1 mol of gaseous oxygen... and you try and heat both to 26 degrees celsius from 25 degrees celsius while they are mixed... can you average the specific heat capacities and then do the equation in one step.. or must you do the calculation for the energy required for water and oxygen separately?
i realize water and air don't mix.. but i still want to know if it holds true in a situation like that :) i suppose water and dissolved salt would make a better example... does the water's capacity get affected by being salinated?
To some 0-th order, maybe; but how and where would you apply such a concept?
Consider, the core is much hotter than the surface, and it will take how long for the two to come to thermal equilibrium?
Also, there are rather too many phase changes that could happen in that 1 degree, so how do you make a sensible average to incorporate that?
Finally, how many chemical reactions will change over that one degree, and by how much?
good points there.. hmm.
never mind then... this gives me lots to think about thx
  • · Replies 28 ·
  • · Replies 67 ·
10K
  • · Replies 19 ·
