Solve Java 1.5 Installation Issue on Ubuntu Linux
  • Context: Java
  • Thread starter Thread starter Tony11235
    Java
The discussion addresses the issue of setting Java 1.5 as the default version on Ubuntu Linux. Users encounter the problem where the command line defaults to Java 1.4 despite installing Java 1.5. The solution involves modifying the .bash_profile to include the export command: export PATH="/usr/lib/jdk1.5.0_06/bin/:$PATH". This adjustment ensures that Java 1.5 remains the default version across terminal sessions.
  • Familiarity with Ubuntu Linux command line operations
  • Basic understanding of environment variables in Linux
  • Knowledge of Java versioning and installation
  • Experience with editing configuration files like .bash_profile
  • Research how to permanently set environment variables in Linux
  • Learn about managing multiple Java versions using tools like SDKMAN!
  • Explore the differences between Java 1.4 and Java 1.5 features
  • Investigate the process of uninstalling older Java versions on Ubuntu
Java developers, system administrators, and anyone managing Java installations on Ubuntu Linux will benefit from this discussion.
Tony11235
I'm on ubuntu linux. I've installed java 1.5 but at the command line, when I type java -verion I get 1.4. So then I type: export PATH="/usr/lib/jdk1.5.0_06/bin/:$PATH". I type java -version and get 1.5, but then when i close the command prompt and open a new one, it's back to java 1.4. Any help on what i need to do to make it permanent?
Technology news on Phys.org
Do you need two versions of java installed? Why don't you uninstall java 1.4?
If you want both versions you can put that export line in your .bash_profile
12K
  • · Replies 25 ·
