Deriving D/dx of Inverse Trig Functions
  • Thread starter Thread starter Chocolaty
    Inverse Trig
The discussion revolves around deriving the derivative of a function involving the inverse tangent function under a square root, specifically the expression y = sqrt(tan^-1(x)). Participants are exploring the application of derivative rules in this context.
  • Participants discuss the use of the chain rule and u-substitution to tackle the derivative. There are attempts to clarify the correct expressions for du and the derivative of the function.
Multiple participants are engaging with the problem, suggesting the chain rule as a key approach. There is some clarification regarding the correct formulation of du, indicating an active exploration of the problem without a clear consensus on the final steps.
There is mention of a lack of answers in the textbook for specific problems, which may influence the urgency and nature of the discussion.
Chocolaty
How do you derive a function where the trig is under a square root
like this:
y=sqr(tan^-1(x))
y=(tan^-1(x))^(1/2)
i know that y=tan^-1u(x) => dy/dx=1/(1+u^2)*du/dx
But how do I work it out? The book doesn't give the answers to pair numbers :(
chain rule?
StatusX said:
chain rule?
Yea that's what I was going to say.
Yeah, chain rule.
[tex]u=\tan^{-1}(x)[/tex]
[tex]du=\frac{dx}{x^2+1}[/tex]
So using u-substitution you can write you function as this.
[tex]y=\sqrt{u}=u^{\frac{1}{2}}[/tex]
[tex]y'=\frac{1}{2\sqrt{u}}*du[/tex]
I think you can make the necessary substitution now.
Jameson said:
Yeah, chain rule.
[tex]du=\frac{1}{x^2+1}[/tex]
The second line is wrong, Jameson.
It should read:
[tex]du=\frac{dx}{x^2+1}[/tex].
dx, not 1 :wink:.
Have you worked out the problem, Chocolaty?
VietDao29 said:
Have you worked out the problem, d_leet?
Yes I have.
d_leet said:
Yes I have.
Ooops, sorry, I mean Chocolaty :biggrin:...
Hope you don't mind. :rolleyes:
lol That's alright.
It should read:
dx, not 1 :wink:.
Tsk tsk. Sorry bout that. Fixed.
  • · Replies 22 ·
