Thread Closed
magnetic dipole moment
Share Thread Thread Tools
Jan29-06, 06:30 PM   #1
Hello, i have absolutely no clue on how to start this one:
a sphere of radius R has a uniform volume charge density [tex]\rho[/tex].
Determine the magnetic dipole moment of the sphere when it rotates as a rigid body with angular velocity [tex]\omega[/tex] about an axis through its center.
thanks for the help on this one
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jan30-06, 05:16 AM   #2
Maybe you can divide the sphere in to many rings. Each ring is a magnetic dipole moment, which magnitude is
[tex] \mu = iA [/tex]
Then integrate them.
By the way, what's the given answer?
Is it
[tex] \frac{4}{15} \rho \omega \pi R^5 [/tex] ?
Jan30-06, 01:16 PM   #3
hello, i do not have the answer at this time, but i tried your method you describe and got the same as you without the 15 in the denominator. can you explain how you ended up with 4/15?
thanks
Jan30-06, 09:45 PM   #4
Hi. There was R^5 and sin^3 in my integration so it ended up with 4/15. It seems that we have some difference from the start. If we use the same idea, it should come out the same result. Can you post you equation?
Thanks
Jan30-06, 11:05 PM   #5
heres what i have done:
since [tex]dV \rho = dq[/tex] and [tex]dt=\frac{2\pi}{\omega}[/tex] so that [tex]I=\frac{dq}{dt}=\frac{dV\omega\rho}{2\pi}[/tex]
now since magnetic moment is [tex]\mu=IA[/tex] i wrote [tex] d\mu = \frac{dV\omega\rho}{2\pi}dA[/tex] then for a sphere the differential volume element i used was [tex]dV= r^2 sin\theta dr d\theta d\phi[/tex]
putting this all together i have
[tex]\mu = \frac{\omega\rho}{2\pi}\int_{0}^{R}r^2 dr\int_{0}^{\pi}sin\theta d\theta\int_{0}^{2\pi}d\phi\int dA[/tex]
where [tex]\int dA = volume of sphere = \frac{4}{3}\pi r^3[/tex]
Jan31-06, 12:00 AM   #6
Quote by thenewbosco
This is the difference.
I think that we can obtain a circle by intersecting a plan and the sphere. There are many many diffrential rings on the circle, each has area
[tex] r^2 sin^2 \phi \pi [/tex]
A bigger ring will involve a small one, so
[tex] \int dA \neq \frac{4}{3} \pi R^3 [/tex]
My solution is similar as yours:
A ring has charge
[tex] q=2 \pi r sin \phi r d \phi dr \rho [/tex]
so each ring has
[tex] i=2 \pi r sin \phi r d \phi dr \rho \frac{\omega}{2 \pi} [/tex]
magnetic moment [tex] \mu = iA [/tex] [tex]A =r^2 sin^2 \phi [/tex]
put this all together
[tex] \mu = \rho \omega \pi \int_{0}^{R}\int_{0}^{\pi} r^4 sin^3 \phi dr d \phi [/tex]
Jan31-06, 12:11 AM   #7
i am wondering what angle phi is on yours, i have used phi and theta as in spherical polar coordinates, while you have only theta. can you describe what this is. thanks
Jan31-06, 01:22 AM   #8
[tex] \theta_{yours} = \phi_{mine} [/tex]
Quote by Psi-String
[tex] \int_{0}^{2 \pi} d \phi_{yours} = 2 \pi_{mine} [/tex]
I'm not 100% sure whether my solution and answer are right or not.
If you have other ideas or know the correct answer, plz tell me.
Thanks a lot
Jan31-06, 08:56 PM   #9
just wondering how you have for area that
[tex]A=r^2 sin^2\phi[/tex]
otherwise your solution looks right to me
Jan31-06, 10:54 PM   #10
Quote by Psi-String
magnetic moment [tex] \mu = iA [/tex] [tex] A=r^2 sin^2 \phi [/tex]
Oh I'm sorry! It should be
[tex] A= r^2 sin^2 \phi \pi [/tex]
Sorry for mistake.
Mar3-09, 01:15 PM   #11
(sorry for all the greek letters in superscript, I don't know why it's doing that...)
I am doing this same question except the sphere only carries a uniform surface charge [tex]\sigma[/tex]. I then obtain the final answer
[tex]4/3[/tex][tex]\pi[/tex]R[tex]\omega\sigma[/tex]
Which is equivalent to
Volume of Sphere x [tex]\omega\sigma[/tex] (+z direction)
Would this be the correct answer?
The only real difference when doing the question is that I only needed to integrate wrt theta instead of over the whole volume since all the charge lies on the surface.
May2-09, 09:18 PM   #12
the correct answer is 1/3*q*(R^2)*w ... now calculate it correctly ....
Thread Closed
Thread Tools
Similar Threads for: magnetic dipole moment
Thread Forum Replies
Magnetic dipole moment Advanced Physics Homework 8
Magnetic Dipole Moment Classical Physics 2
why is the electric dipole moment of an atom zero, but the magnetic moment nonzero? Quantum Physics 9
Magnetic dipole moment Advanced Physics Homework 1
Magnetic dipole moment help please Advanced Physics Homework 0
