Deep space object in zero gravity subject to forces
The discussion revolves around a physics problem involving a 1.4 kg object in deep space, subjected to multiple forces. Participants are exploring how to determine the object's velocity after a specified time under the influence of these forces, focusing on the concepts of force, acceleration, and motion in a zero-gravity environment.
  • Participants discuss breaking down the forces into x and y components and calculating the resultant force. There are attempts to apply Newton's second law (F=ma) and kinematic equations to find the final velocity. Some participants question the initial assumptions about the direction of forces and the initial conditions.
The discussion is active, with participants providing guidance on how to calculate acceleration and velocity. There are differing interpretations of the force components, particularly regarding the direction of the forces, which suggests a need for clarification. While some participants offer formulas to use, there is no explicit consensus on the correct approach yet.
Participants are navigating potential misunderstandings related to the direction of forces and the initial conditions of the problem. The original poster expresses uncertainty about the relationship between force, acceleration, and velocity, which is a critical aspect of the discussion.
lomantak
The 1.4 kg object below is at rest, suspended in deep space, far from any planet or other body. If the forces shown below are exerted simultaneously on the object, what will be the velocity of the object after 3.5 s?
http://www.geocities.com/monsieurgoontaz/images/image1.jpg
Split into x and y, so ...
For x:
[tex][2.9cos(30)]-6.4[/tex]
[tex]=-3.889[/tex]
For y:
[tex][2.9sin(30)]+4[/tex]
[tex]=5.45[/tex]
So take the sums of X and Y and do pythag, getting 6.6953 at -35.5 degrees as the resultant. Then taking the resultant force, plug it into [tex]F=ma[/tex]? The question asks for velocity, but the formula [tex]F=ma[/tex] only has the acceleration. Any help is greatly appreciated! Thanks!
You can find the acceleration, and you know the acceleration continues for 3.5 seconds. You should be able to find the final velocity by simply using:
[itex]v(t) = v_0(t) + a t[/itex]
- Warren
use v = u + at
where
v = final velocity
u = initial velocity
a = acceleration
1. Oooooh, careful! The y-component of the 2.9 N force is obviously acting downward (in the negative y-direction), yet you have not accounted for this. Keep in mind that the angle shown is, by convention, -30 degrees, or 330 degrees if you prefer. Using that value will give you the correct answer for both x-component and y-component.
2. Come on! Think! You have an initial velocity of zero. You have the acceleration, which is the rate at which the velocity changes with time. You also have a given time interval during which the object has that acceleration. Surely you know what the velocity will be at the end of that time interval...
  • · Replies 41 ·
  • · Replies 22 ·
