Thread Closed
Parity in the \eta to two photon decay
Share Thread
Feb4-06, 08:09 PM   #1
Greetings, I'm curious about parity conservation in the decay[tex]\eta \rightarrow \gamma \gamma[/tex]. The [tex]\eta[/tex] has odd parity, while the product of the two photon parities (each is odd) is even. Now, parity is conserved in the EM interactions, so there must be a factor of (-1) coming in from orbital angular momentum factors--but the two photon final state has no orbital angular momentum. What am I missing here?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb7-06, 04:20 PM   #2
IN SHORT : PARITY DOES NOT ADD UP LINEARLY...
I mean : in order for the two-photon state to have J = 0 (conservation of J we must write it as a superposition of two states A and B. Each state has the two photons with anti-parallel spins and in state A the photonspin is aligned with the photon-momentum, in B photon spin is opposite wrt photon momentum. You can derive these states by using the Clebsch-Gordan coefficients.
A photon has indeed parity -1 but since we are working with a superposition of TWO photonstates, the parity is relative. If you had just a single two-photon state then parity would be -1 * -1 but because of the superposition, it is the parity from state A with respect to state B that determins the actual parity of the entire wavefunction...
regards
marlon
More to be found here
Feb8-06, 05:02 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by fliptomato
In \eta-->2\gamma, there is orbital angular momentum l=1, which gives the factor (-1)^l. The angular momentum addition for the photon spins must be S=1+1=1, and then l+S=1+1=0.
The eta decay is the same as the pi^0 decay. The parity of the pi^0, and of the eta^0, were determined by the relative plane polarizations of the two photons, which can be found from the spin addition 1+1=1.
This was first done by Yang.
Thread Closed
Similar discussions for: Parity in the \eta to two photon decay
Thread Forum Replies
Chiral anomaly, pion to photon decay High Energy, Nuclear, Particle Physics 2
A little confused about photon decay Introductory Physics Homework 3
radioactive decay equilibrium when decay constants are equal Biology, Chemistry & Other Homework 2
neutron decay products: n → p + e + ν + DC-photon? High Energy, Nuclear, Particle Physics 18
parity in pion decay High Energy, Nuclear, Particle Physics 1
