How Does Friction Affect Speed on a Sloped Ramp?
  • Thread starter Thread starter pureouchies4717
    Acceleration Slope
The discussion revolves around a physics problem involving a wood block launched up a wooden ramp inclined at a 30-degree angle, with considerations of kinetic friction affecting its motion. Participants are exploring the implications of friction on the block's speed as it moves up and then slides back down the ramp.
  • Exploratory, Assumption checking
  • Participants are questioning the interpretation of the problem, specifically whether the question pertains to the final velocity of the block as it returns to its starting point. There is also a mention of a previous misunderstanding regarding the calculation involved.
The discussion is active, with participants clarifying the question's intent and addressing previous errors in calculations. Some guidance has been provided regarding the interpretation of the final velocity in the context of the problem.
There is a mention of a specific coefficient of kinetic friction and the initial conditions of the block's speed and mass, which may influence the calculations being discussed. Participants are also reflecting on their own mistakes in the problem-solving process.
pureouchies4717
im having a lot of trouble with this one also:
A 2.0 kg wood block is launched up a wooden ramp that is inclined at a 30 degree angle. The block's initial speed is 10m/s. The coefficient of kinetic friction of wood on wood is .200.
What speed does it have when it slides back down to its starting point?
PROBLem is solved folks, thanks for the help HallsofIvy
is the second question asking for the final velocity or the initial?
Well, you said "What speed does it have when it slides back down to its starting point?" It slides up the slope, then back down. Assuming that by "final velocity" you mean its velocity as it passes that initial point the second time, yes, that is what is asked.
arg that's what i thought, but i got that answer wrong
EDIT: it was a simple multiplication problem
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 21 ·
