Designing Voltage Dividers w/o Resistors & <1 Gain Amplifiers
  • Thread starter Thread starter mcfetridges
    Voltage
This discussion focuses on designing voltage dividers without resistors and creating amplifiers with a gain of less than one. Reactive components such as inductors and capacitors can be utilized to form voltage dividers for AC signals, although they may introduce phase shifts and frequency-dependent behavior. Active transistor voltage dividers are also possible, but typically involve resistors in their bias networks. Amplifiers with gain less than one are commonly used for buffering signals, leveraging high input impedance to minimize distortion while providing low output impedance for driving loads.
  • Understanding of AC signal behavior and reactive components
  • Knowledge of L-C lowpass filter configurations
  • Familiarity with transistor biasing techniques
  • Concept of amplifier input and output impedance
  • Research the design of L-C lowpass filters for voltage division
  • Explore active transistor configurations for voltage dividers
  • Learn about high input impedance amplifiers and their applications
  • Investigate methods for achieving adjustable gain in amplifiers
Electronics engineers, circuit designers, and hobbyists interested in innovative voltage divider designs and low-gain amplifier applications.
mcfetridges
Is it possible to design voltage dividers that do not primarily use resistors. Could you make a <1 voltage gain amplifier? What is usually done in real applications?
Thanks
If you are working with an AC signal, you can use reactive elements like inductors and capacitors to form a voltage divider. However, keep in mind that you may get some phase shift in the divided output voltage, depending on what mix of components you use, and you may get a frequency-dependent behavior, as in an L-C lowpass filter configuration. Also, series capacitors are not generally used alone to form AC voltage dividers, since the DC voltage in the middle of two series-connected caps is not really defined by anything (except leakage current). Large value bleeder resistors would generally be placed around series-connected caps like that.
You could also make an active transistor voltage divider, I suppose. Although you would most likely be using resistors in the bias networks for the transistors.
As for an amplifier with gain <1, yes, that is sometimes done. Usually it is done as part of buffering a signal. You use an amplifier that has a high input impedance compared to the output impedance of the source voltage, so that the signal is not distorted much by going into the input of the amplifier. And the amplifier takes power from the power supply to generate a copy of the input signal at the low-impedance output of the amp. This low output impedance of the amp allows it to drive moderate input impedance loads, again without much distortion on the signal. The overall gain through such a buffer amp can be 1, or >1 or <1, or even adjustable, depending on the application.
What is the context of your question? We can probably give you a better answer if we know what your intended application is.
  • · Replies 40 ·
  • · Replies 33 ·
  • · Replies 29 ·
