Force of friction in circular motion
The discussion focuses on calculating the coefficient of friction required to prevent skidding for a car moving at 90.0 km/hr on a perfectly banked curve with a radius of 80.0 m. The angle of the banked curve is determined using the formula tan(theta) = v^2/(Rg), where R is the radius and g is the acceleration due to gravity. The key to solving the problem lies in analyzing the forces acting on the car: the normal force, gravitational force, and frictional force. By resolving these forces into their vertical and horizontal components, one can establish the necessary conditions for maintaining circular motion without skidding.
  • Understanding of circular motion dynamics
  • Knowledge of forces: normal force, gravitational force, and frictional force
  • Ability to apply trigonometric functions in physics
  • Familiarity with the concept of centripetal force
  • Study the derivation of the formula tan(theta) = v^2/(Rg) in circular motion
  • Learn how to draw free-body diagrams for objects in circular motion
  • Explore the relationship between banking angle and friction in vehicular motion
  • Investigate the effects of varying speeds on the coefficient of friction required for safe navigation of curves
This discussion is beneficial for physics students, automotive engineers, and anyone interested in understanding the dynamics of vehicles on banked curves and the role of friction in preventing skidding.
kbrowne29
I'm having trouble with the following problem:
If a curve of radius 80.0 m is perfectly banked for a car moving 70.0 km/hr, what must be the coefficient of friction in order to prevent skidding when the car is moving at 90.0 km/hr.
OK, I know that I need to find the angle of the "perfectly banked" curve first, and I am able to do this. However, what do I do with this angle? It seems that there are too many unknowns.
I know that tan(theta)=v^2/Rg, where r is the radius of the circle. But I'm not sure where to go from here. I would really appreciate any help with this problem. Thanks.
damn it i misread the question. sorry.
I don't know about that formula you mentioned -- it may or may not apply to this problem, & I suspect not.
Anyway, applying a formula is not the way to attack a problem. Think about the geometry of the situation, & then draw a diagram of the forces. You have three: the normal force acting perpendicular to the banked surface, the gravitational force acting vertically down, and friction acting on an angle downward and towards the center of curvature (parallel to the road surface).
You want to resolve the normal force and the friction into their vertical and horizontal components, so the sum of the vertical forces (the gravity plus the vertical components of the normal and frictional forces) is zero, and the sum of the horizontal components of the frictional and normal forces equals the centripetal force needed to keep the car moving along that curve. Knowing "theta" allows you to do that.
Start with the drawing. Then do the trig.
  • · Replies 18 ·
  • · Replies 20 ·
