Why does multiplying the positive x values give the y-intercept on a parabola?
  • Thread starter Menos
  • Tags
    Graph
In summary, by multiplying the positive x values (2*4=8), you can get the y-intercept of the line from (-2,4) to (4,16) in the equation y=2x+8. This works because the slope of the line is the sum of the x coordinates, which can be seen from the 2-point formula for a line and the equation of the parabola y=x^2.
Menos
Interesting feature of this graph. Consider 2 points on the parabola, I'll take (-2,4) and (4,16). By multipling the positive x values (2*4=8), you can get the y-intercept of the line from (-2,4) to (4,16). Proof: The line including (-2,4) and (4, 16) is written as y=2x+8. Thus, the y-intercept is 8. My question is why does this work? I've been trying to figure it out for a while, and I am completely stumped on this one... Any help would be greatly appreciated! :smile:
Mathematics news on Phys.org
First find the general equation for the slope b in terms of x1, y1, x2, and y2. Then use the fact that y1 = x1^2 and y2 = x2^2.
Actually it's not the product of the absolute value of the x values, it's the opposite of the product of the x values.
Start from the 2 point formula for a line.
[tex] \frac {y - y_1} {x - x_1} = \frac {y_2 - y_1} {x_2 - x_1} [/tex]
The formula for your parabola is
[tex] y = x^2 [/tex]
So we can write
[tex] y_1 = x_1^2 [/tex]
and
[tex] y_2 = x_2^2 [/tex]
Use this information in the 2 point formula to get
[tex] \frac {y - y_1} {x - x_1} = \frac {x_2^2 - x_1^2} {x_2 - x_1} [/tex]
Note that the numerator on the Right Hand Side is the differenc of squares and can be factored to get
[tex] \frac {y - y_1} {x - x_1} = \frac {(x_2 - x_1) (x_2 + x_1)} {x_2 - x_1} [/tex]
Cancel like factors in the RHS
[tex] \frac {y - y_1} {x - x_1} = (x_2 + x_1) [/tex]
Now rearrange this to get
[tex] y - y_1 = (x - x_1) (x_2 + x_1)[/tex]
Simplify to get:
[tex] y = x (x_2 + x_1) - x_1 x_2[/tex]
Clearly you are correct for the simple parabola, in addition it can be seen that the slope of the line is the sum of the x coordinates.
1. What is the shape of the graph of y=x^2?
The graph of y=x^2 is a parabola, which is a U-shaped curve.
2. What are the key points on the graph of y=x^2?
The key points on the graph of y=x^2 are the vertex, which is the lowest or highest point on the parabola, and the x-intercepts, where the parabola crosses the x-axis.
3. What is the equation for finding the y-value of a point on the graph of y=x^2?
The equation for finding the y-value of a point on the graph of y=x^2 is y=x^2, where x is the x-coordinate of the point.
4. How do you graph y=x^2 on a coordinate plane?
To graph y=x^2 on a coordinate plane, you can plot points by choosing specific values for x and finding the corresponding y-value using the equation y=x^2. You can also use the key points mentioned in question 2 to help create the parabola.
5. What is the domain and range of the graph of y=x^2?
The domain of y=x^2 is all real numbers, as any value for x can be squared. The range of y=x^2 is all non-negative real numbers, as the lowest point on the parabola is 0 and it extends upwards infinitely.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
9K
