Easy and quick Special Relativity before my exam
This discussion focuses on the application of Lorentz time dilation and the full Lorentz transformation in special relativity. The user seeks clarification on when to apply simple time dilation, as demonstrated in the spaceship example, versus the full Lorentz transformation, as illustrated in the photon emission scenario. The key distinction lies in the number of clocks involved: simple time dilation applies to a single moving clock, while the full Lorentz transformation is necessary when multiple clocks are required to measure events across different frames of reference.
  • Understanding of Lorentz time dilation
  • Familiarity with Lorentz transformations
  • Basic concepts of reference frames in special relativity
  • Knowledge of photon behavior in different inertial frames
  • Study the derivation and applications of Lorentz transformations
  • Explore examples of time dilation in various inertial frames
  • Learn about simultaneity and its implications in special relativity
  • Investigate the relationship between velocity and time perception in relativistic contexts
Students preparing for exams in physics, particularly those focusing on special relativity, as well as educators seeking to clarify concepts related to time dilation and Lorentz transformations.
mewmew
Well I am having my exam tomorrow over special and very basic general relativity. I have one area I am still a bit fuzzy on now that I look back at our last exam. I am confused on when you can use just Lorenz time dilation/length contraction to when you need to use the full Lorenz transformation.
For example: In one problem we were given a spaceship leaves Earth to a star distance x away(in the Earth reference frame), the spaceship has a velocity of y with respect to the earth. How long does it take to get to to asteroid in the Earth reference frame? The ships? This you can use simple time dilation.
Our next problem was: Frame S' has a speed of x relative to S, clocks are adjusted so that t'=t=0. A photon is emitted in S at x=0 and absorbed at x=50 m, what time does this event occur in S'? This you need to use the full Lorentz transformation.
I am sure it is pretty simple to understand when and why you can use one or the other but I am a bit confused. Thanks for any help!
Simple time dilation describes the behavior of a single moving clock. That applies perfectly to your first example (the spaceship's clock is that single moving clock), but not to the second. In the second example, no single clock times the emission and absorption of that photon: multiple clocks in each frame are needed to measure the travel time. That requires the full Lorentz transformations.
  • · Replies 40 ·
