Is This Equation Correct for Horizontal Projection?
The discussion centers on deriving the relationship between vertical distance fallen (y) and horizontal distance traveled (X) for a block sliding off a horizontal surface with an initial speed (Vo). Participants confirm that using the horizontal projection equations is appropriate, leading to the expression y = 0.5g(x/Vo)^2. This equation can be simplified to (square root of y/4.9) = X/Vo, accurately representing the physics of horizontal projection. The consensus is that the original form of the equation is sufficient and should not be overly simplified.
  • Understanding of horizontal projectile motion
  • Familiarity with the equations of motion in physics
  • Knowledge of gravitational acceleration (g = 9.8 m/s²)
  • Basic algebra for manipulating equations
  • Study the principles of horizontal projectile motion in detail
  • Explore the derivation of projectile motion equations
  • Learn about the effects of air resistance on projectile motion
  • Investigate real-world applications of horizontal projection in engineering
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of horizontal projection in real-world scenarios.
Physicsisfun2005
I think this physics problem deals only with horizontal projection...let me know what you think:
A block slides off a horizontal surface with speed Vo. Write an expression relating y, distance fallen, to X, the horizontal distance traveled.
i think i can use the horizontal proj. equations:
R=volt (I think you can substitute X for R)
h=.5gt^2 (I think you can substitute y for h)
I get a combined equation of y=.5g(x/Vo)^2..which simplfied b/c .5g=4.9
Y/4.9=(X/Vo)^2...which i think can simplify to the
(square root of y/4.9)=X/Vo
That is correct, and I would leave it in exactly that form. The rest of your "simplifications" really just seemed to make a mess of it. You are asked to express y as a function of x (or x as a function of y), and that's exactly what you've done. You're finished!
- Warren
Yes, you are correct. The problem only deals with horizontal projection, as the block is sliding off a horizontal surface. Your approach of using the horizontal projection equations is correct. By substituting X for R and y for h, you can arrive at the expression y=.5g(x/Vo)^2, which can be simplified to (square root of y/4.9)=X/Vo. This equation relates the distance fallen, y, to the horizontal distance traveled, X. Great work!
