Silver staining and chromosome spreads
  • Thread starter Thread starter kalladin
    Silver
The discussion focuses on the challenges of silver staining chromosome spreads on plastic coated slides, specifically the issue of the plastic coating detaching during water rinses. The user employs a 50% silver nitrate solution and a nylon mesh cover for staining, which takes approximately 1.5 hours with additional staining every 15 minutes. The problem arises after the staining process, where the plastic coating comes off, potentially due to the interaction of the staining solution with the plastic. The user fabricates their own plastic coated slides using a 0.6% solution of dissolved Falcon plastic petri dishes in chloroform.
  • Understanding of silver staining techniques in electron microscopy.
  • Knowledge of plastic coating procedures for microscope slides.
  • Familiarity with the properties of silver nitrate solutions.
  • Experience with preparing and handling nylon mesh covers for staining.
  • Research best practices for silver staining chromosome spreads using plastic coated slides.
  • Investigate alternative plastic materials for slide coating that resist detachment during rinsing.
  • Learn about the effects of temperature and solution interactions on plastic coatings in staining procedures.
  • Explore troubleshooting methods for common issues in electron microscopy staining techniques.
This discussion is beneficial for researchers and technicians involved in electron microscopy, particularly those working with chromosome spreads and silver staining techniques. It is also relevant for anyone involved in the preparation of plastic coated microscope slides.
kalladin
Hi, I don't know if anyone here can help me. But I've lately been silver staining chromosome spreads for EM on plastic coated slides. However, when I do the water rinses after the staining procedure, my plastic coating just comes off and it infuriates me to no end as the whole spreading/staining procedure takes me 8 hours (6 on a good day). Does anyone have any experience and/or advice for me? I've been staining them with silver nitrate (50%) and a nylon mesh cover for 1.5 hours and adding additional stain every 15 minutes. I don't 'think this has anything to do with the temperature. I DO see some weird stuff happening that doesn't happen with normal glass slides- like how the solution bubbles up (i'm thinking some of the stain went under the plastic)?
I will appreciate any help!
Kevin
Biology news on Phys.org
Do you buy the plastic coated slides from a company? If so, contact them and ask if they can give you advice. If you make them yourself, you need to provide us with information what kind of plastic it is and how you coat them.
Hi Monique,
I make my own plastic coated slides. I dissolve plastic petri dishes (made by Falcon) in chloroform to make a 0.6% solution. My coating procedure involves dipping the cleaned slides into the solution for 10-15s then taking them out and immediately dipping them again for another 10s. I hang dry them in the container for a minute then remove and air dry in a dust free area. The slides turn out well and a test to see if the plastic floats off onto water turns out well.
  • · Replies 26 ·
9K
  • · Replies 18 ·
  • · Replies 21 ·
