Calc 3 Project: Solve Arc Length Problem with y = 1/c cosh(cx + b) + a
The discussion revolves around a project in Calculus 3 involving the arc length of a hanging cable described by the equation y = 1/c cosh(cx + b) + a. The endpoints of the cable are given, and the total length is specified as 100 units. Participants are exploring how to determine the constants a, b, and c based on these conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the arc length formula and its application to the problem, noting difficulties in solving the resulting equations for a, b, and c. There are mentions of using derivatives and the software Maple for assistance, as well as suggestions to simplify expressions using hyperbolic identities.
The conversation is ongoing, with participants sharing insights and corrections regarding the derivative and the use of Maple. Some guidance has been offered on how to approach the problem, including hints for eliminating variables and using hyperbolic identities, but no consensus has been reached on a solution.
Participants are working under the constraints of a project assignment, which may impose specific requirements on how to approach the problem and the use of technology. There is also a noted complexity in the equations derived from the conditions provided.
SigurRos
Hey I got a project assigned for my Calc 3 class, and I was wondering what to do with the following:
A hanging cable has the shape
for some constants a,b,c with c>0. Suppose the ends are at P(0,10) and P2(30,5).
If the length of the cable is known to be 100 units then determine a,b,c and then plot the graph.
I know that dy/dx = sinh(cx + b), so the arc length formula would be:
100 = int(sqrt(1 + sinh(cx + b)^2)) from 0 to 30
but I'm having issues solving the equations in terms of a,b and c. I tried, and got an equation with lots of cosh's that myself and Maple could not solve or reduce.
Any advice?
Thanks a lot!
Any advice?
Thanks a lot!
you can simplify the
1 + sinh(cx + b)^2 into just (cosh(cx + b))^2.
And you were given 2 points which you can use to find equations relating a, b , and c.
d_leet said:
You forgot a 1/c in your derivative
Maple computed the derivative for me, and that is what it gave me.
Also, I did use those 2 points to construct 2 equations, but when I tried to solve for the system I got a complex equation with lots of cosh's that maple couldn't solve.
Ohh wow I feel dumb your deriavtive is right. I forgot to multiply by c..
Newton's method? :biggrin:
You are relying on Maple far too much. You should be able to compute the derivative by hand. You will need to guide Maple to find an approximate solution, with most of the work done by hand.
Hints:
1. Eliminate a.
2. Use the hyperbolic identities for cosh(u)-cosh(v) and sinh(u)-sinh(v).
3. Find tanh(15c+b).
