Removing magnetism from a magnet with electricity?
Removing magnetism from a magnet can be effectively achieved using a degaussing coil, which utilizes a decaying AC magnetic field to demagnetize materials. The discussion specifically mentions using 12 volts and 2.5 amps DC, but emphasizes that a degaussing coil is the most common and effective method for this purpose. This technique works by manipulating the B-H curve of the magnetized material, bringing it back to a neutral state where no residual magnetism remains.
  • Understanding of electromagnetic principles
  • Familiarity with degaussing techniques
  • Basic knowledge of AC and DC electrical systems
  • Experience with electrical components and circuits
  • Research the design and operation of degaussing coils
  • Learn about the B-H curve and its significance in magnetism
  • Explore the differences between AC and DC power in demagnetization
  • Investigate safety protocols when working with electrical components
Electronics engineers, hobbyists working with magnets, and anyone interested in demagnetization techniques will benefit from this discussion.
MooShuPork
Hey everyone, wondering if anyone knows if it's possible to remove the magnetism from a magnet through use of electicity. Specifically using 12volts, 2.5 amps DC.
I'm looking for some kind of switch, or converter etc, that would remove the magnetism, but obviously I don't know exactly what I'm looking for.
Any help would be appreciated, thanks =)
The key term you should look for is degaussing coil. That is the most common way to demagnetize stuff. It uses a decaying AC magnetic field to work the B-H curve of the magnetized material back down to the center, so there is no Br left.
Just google "degaussing coil" and you should get some useful hits.
