Can you spot the error in this integration by substitution problem?
The discussion revolves around an integration by substitution problem involving the integral of the form ∫ x·u^(1/2) where u = 2x - 1. Participants are examining the steps taken in the integration process and questioning the correctness of the approach and calculations.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the substitution of variables and the integration steps. There are questions about the correctness of the initial setup and whether further substitutions are necessary. Some participants express confusion over the multiplication factors used in the integration process.
The discussion is ongoing, with various interpretations of the integration steps being explored. Some participants provide guidance on the integration process, while others question the initial assumptions and calculations. There is no explicit consensus on the correctness of the original approach.
Participants note the importance of including the constant of integration and discuss the linearity of the integral in question. There are references to potential missing elements in the original integral setup.
Hootenanny
Staff Emeritus
The question is to find the following intergal:
[tex]\int x\cdot u^{\frac{1}{2}[/tex] where [itex]u = 2x -1[/itex].
[tex]= \int x\cdot u^{\frac{1}{2}} \;\; \frac{1}{2} du[/tex]
[tex]u = 2x -1 \Rightarrow x = \frac{u+1}{2}[/tex]
[tex]= \int \frac{1}{2}(u+1)\cdot u^{\frac{1}{2}} \;\; \frac{1}{2} du \;\; = \int \frac{1}{4}\left( u^{\frac{3}{2}} + u^{\frac{1}{2}}\right) \;\; du[/tex]
[tex]= \frac{2}{20} u^{\frac{5}{2}} + \frac{2}{12} u^{\frac{3}{2}} = \frac{1}{10} u^{\frac{5}{2}} + \frac{1}{6} u^{\frac{3}{2}}[/tex]
But this isn't going to give me the correct answer. Can anybody see where I've gone wrong? Thank's
If u= 2x- 1 then 2x= u+1 so x= (1/2)(u+1). Substitute THAT for x and the integral becomes
[tex]\frac{1}{2}\int(u+1)u^{\frac{1}{2}}du= \frac{1}{2}\int (u^{\frac{3}{2}}+ u^{\frac{1}{2}})du[/tex]
That should be easy to integrate.
[tex]\frac{1}{2}\int (u^{\frac{3}{2}}+ u^{\frac{1}{2}})du = \frac{1}{2} \left[ \frac{2}{5} u ^{\frac{5}{2}} + \frac{2}{3} u^{\frac{3}{2}} \right][/tex]
Is that correct?
Or would i have to make a further substitution for [itex](u^{\frac{3}{2}}+ u^{\frac{1}{2}})[/itex] ?
That's correct, but don't forget the constant of integration :smile:
Thank's TD +c
Hootenanny said:
Thank's TD +c
You're welcome.
To get back to your last question, there is no need for an extra substitution since the integral is lineair, which means that:
[tex]\int {\alpha f\left( x \right) + \beta g\left( x \right)dx} = \alpha \int {f\left( x \right)dx} + \beta \int {g\left( x \right)dx}[/tex]
So in your case, that gives:
[tex]\int {u^{\frac{3}{2}} + u^{\frac{1}{2}} du} = \int {u^{\frac{3}{2}} du} + \int {u^{\frac{1}{2}} du}[/tex]
Then you can apply the standard exponent-rule, as you did.
What? He had it completely right the first time. 1/4 is the correct thing to multiply by because dx = 1/2 du. I'm assuming there was a dx in the original integral because otherwise he wouldn't have included the 1/2 du in his second step.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 27 ·
