Why are UV photons absorbed by glass?
  • Context: High School
  • Thread starter Thread starter mark2711
    Glass Transparent
Glass is transparent primarily because it does not absorb much light in the visible spectrum, reflecting only about 4% of incoming photons due to its non-metallic nature and lack of free electrons. When photons interact with glass, if their energy does not match the energy transitions of the atoms, they are absorbed and reemitted rather than absorbed completely. However, glass does absorb UV photons, preventing UV radiation from penetrating and causing tanning through the material.
  • Understanding of photon behavior in materials
  • Knowledge of atomic energy transitions
  • Familiarity with the properties of glass
  • Basic principles of light reflection and refraction
  • Research the interaction of UV light with different materials
  • Study the atomic structure of glass and its energy transitions
  • Explore the principles of light reflection and refraction in non-metallic substances
  • Investigate the effects of UV radiation on human skin and protective measures
Physicists, materials scientists, and anyone interested in the optical properties of materials, particularly in relation to UV light absorption and transparency.
mark2711
I have never really thought about so any help would be great.
Science news on Phys.org
It is transparent for several reasons. It does not absorb much light in the visible spectrum. It reflects very little light because its index of refraction is fairly close to that of air. It does not scatter light because it is usually made to be smooth compared to the wavelength of visible light.
Njorl
Light, as photons, have few choices as to what can happen when they hit "stuff." Reflection, absorption, and transmission are the general classifications of options.
Since glass is not metallic, and has few "free" electrons, only about 4% of the photons will be reflected. (This is assuming the light is not all the same color. Things get more interesting with momochromatic light.)
Photons that are not reflected will interact with the atoms and molecules of the matter. If the atoms and molecules of the "stuff" have electron shells with energy differences that match the energy of the photon, then that photon will be absorbed, and it's energy will serve to heat up the material (again, this is generally speaking.)
If the atoms and moleculaes do not have such "energy transitions" that match the energy of the photon, then the photon will be absorbed and then reemitted by the atoms/molecules.
Glass so happens to not have energy transitions that match the energy of visible photons, so photons are absorbed then reemitted by each of the atoms it hits.
Glass does, however, absorb UV photons, which is why you can't get a suntan through glass.
10K
35K
